4 members (RichardV6, Hamwich, TeddyAds, Chris Cosher), 289 guests, and 38 robots.
+8Rich 92
Posts837,278
Page 10 of 10 1 2 8 9 10
I was so preoccupied with the central screw nut that I tried your recommendation right away.
Pour boiling water over the screw nut... wait two minutes and lo and behold, the nut can be loosened.
Thank you, John, for your first-class and quick help 👍
Clemens
PlusFour Red Baron MY 2022
1 member likes this: John V6
Anyone know where to buy those sockets in the UK ?
My CX came with a flat open hex spanner & a mallet. It sits awfully close to the wire wheel rims, not the best design !!
Thanks.. Martin
MartinB60 #831289 28/09/25 06:51 PM
Thanks.. Martin
Lionel Roberts made various versions for plain and "eared" spinner nuts https://franks4x4-morgantechnical.blogspot.com/2019/11/a-lionel-roberts-alloy-wheel-spinner.html, No longer available direct as far as I know, and I sold mine (sorry) when I switched to eared spinners, but they turn up on line occasionally
1 member likes this: MartinB60
Mulfab make angled longer handled versions of your mm one.
I have alloys now but am keeping my mulfab and Lionel spanners for now
I use this brass jobbie, despite years of abuse it works well and very reasonably priced
https://shop.mwsint.com/product_details.asp?id=179
The pre-warming works too, because the spinners are solid brass and the heat expends them more than the steel threaded hub and cracks open the bond
MartinB60 #831314 29/09/25 01:52 PM
I made mine myself/had it made.
Brexit is unfortunately making exchanges more difficult. But if you like, I can send you a drawing via private message.
Clemens
