0 members (), 281 guests, and 37 robots.
+8Rich 93
Posts837,277
#831986 11/10/25 02:17 PM
Chaps, another little question, the petrol tank, I assume that it must be vented somewhere however each time I go to fill up, the locking tank cap is very hard to remove but when it does come out, thee seems to be an in rush of air. I have never noticed this on the previous 4 Morgans which all had the same type of locking cap, all bright ideas gratefully received.
Reg
lowebird #831989 11/10/25 02:47 PM
Later cars have a closed system only venting fume to the engine above certain rpm to reduce emmissions.
If there is a vacuum there is a relief valve. So when you open it you can find it pressurised
lowebird #832001 11/10/25 04:52 PM
I give the inner rotating bits of the petrol cap a squirt of silicon spray a couple of times a year.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
lowebird #832003 11/10/25 05:32 PM
Once off I put a smear of silicon grease on the white nylon part of inner cap, repeating every three months.
lowebird #832023 12/10/25 09:59 AM
Thank you chaps, once again it just goes to show how good T.M. is, I wasn't aware of the system being sealed.
Reg
lowebird #832034 12/10/25 02:06 PM
We have a spare key for the petrol tank in the car. Sooner or later it will crack while trying to open.
Plus 4 110 Edition 2019
lowebird #833238 02/11/25 10:34 PM
Apart from o rings and such like , I never use silicon anywhere on any car, especially a spray form - if it gets on your paintwork it will cause all sorts of issues.
1999 Morgan Plus 8. 3.9 ....
1961 Alvis TD21 Series1 3 Litre Auto....
lowebird #833250 03/11/25 10:07 AM
Black Rat
Black Rat
The Ethanol in petrol can cause the plastic parts to swell, I had this problem on my KTM M/C. The remedy was to sand the plastic down slightly.
Keith
2013 narrow bodied + 4 Ruby.
