1 members (Alastair),
319
37
Posts837,276
Posts: 5,549 Likes: 67
Posts: 5,549 Likes: 67 |
Chaps, another little question, the petrol tank, I assume that it must be vented somewhere however each time I go to fill up, the locking tank cap is very hard to remove but when it does come out, thee seems to be an in rush of air. I have never noticed this on the previous 4 Morgans which all had the same type of locking cap, all bright ideas gratefully received.
Posts: 27,802 Likes: 749
Posts: 27,802 Likes: 749 |
Later cars have a closed system only venting fume to the engine above certain rpm to reduce emmissions. If there is a vacuum there is a relief valve. So when you open it you can find it pressurised
Posts: 2,085 Likes: 69
Posts: 2,085 Likes: 69 |
I give the inner rotating bits of the petrol cap a squirt of silicon spray a couple of times a year.
Posts: 8,657 Likes: 407
Posts: 8,657 Likes: 407 |
Once off I put a smear of silicon grease on the white nylon part of inner cap, repeating every three months.
Thank you chaps, once again it just goes to show how good T.M. is, I wasn't aware of the system being sealed.
Posts: 104 Likes: 18
Posts: 104 Likes: 18 |
We have a spare key for the petrol tank in the car. Sooner or later it will crack while trying to open.
Plus 4 110 Edition 2019
Posts: 238 Likes: 3
Posts: 238 Likes: 3 |
Apart from o rings and such like , I never use silicon anywhere on any car, especially a spray form - if it gets on your paintwork it will cause all sorts of issues.
1999 Morgan Plus 8. 3.9 .... 1961 Alvis TD21 Series1 3 Litre Auto....
Posts: 5,437 Likes: 131
Black Rat Charter Member
Posts: 5,437 Likes: 131 |
The Ethanol in petrol can cause the plastic parts to swell, I had this problem on my KTM M/C. The remedy was to sand the plastic down slightly.
