0 members (), 286 guests, and 19 robots.
+8Rich 94
Posts837,276
I remembered my second question after my previous brush with Mr Chianti !!!
The window on my passenger side sidescreen is stuck in the 'closed' position with no movement whatsover.
Tried PTFE spray blah, blah, blah before having a good look into both the bottom and top slots.
The top of the screen appears to have dug into the slot that is created by the soft plastic stuff, becoming embedded.
Anybody else had this issue? I'd have a go at repairing this if I knew how the sidescreen came apart!
Maybe one for Dave W? (I've had your book for about 7 yrs btw - it's been very useful... just not on this sidescreen issue! confused2)
I have a picture... if only I could work out how to add them to posts!
2019 Roadster 110 Anniversary
1999 4/4
Vespa PX125
Royal Alloy GP125MT
Does 'attaching a file' work? confused2
1999 4/4
Vespa PX125
Royal Alloy GP125MT
That looks like it's not actually in the channel rubber properly, hence it's stuck
options are take it out and start again, or (less stress on the perspex) try sliding a credit card down the edge and re-seat the channel rubber
A little silicone grease may help with Jon's suggestion. Also have look at the driver's side sliding window for a better idea of how the other side one should sit in the channels.
Should have said that I’d already had a go with the PTFE spray and a thin blunt
knife to relocate the Perspex in the rubber slot!
It looks like it’s really dug in unfortunately.
I think the best bet would be to get the Perspex out and try to reshape the rubber slot.
Does the frame come apart or is it a case of warming the Perspex and trying to coax the screen out before any repair? 🤔
1999 4/4
Vespa PX125
Royal Alloy GP125MT
The frame doesn't come apart. The perspex, fixed and sliding, is sprung in/out but considerable bend has to be put on it. A little heat may help in softening the slide channels if there's any chance of reseating it.
They do push out but in my experience they crack. A good perspex supplier can cut new ones. GoMog has an article but the dimensions are for short door cars.
Well this is a common issue however don't get stressed here as there are several things to bear in mind.
!st that has definitely jumped out of the runner. The plastic material is a non shattering type and the way to reseat the window is to flex the panel enough to loosen it and re seat it into the channel. The front element is not designed to slide, just the rear! Go on you can really bend them!
2nd If when you have reseated the panels don't be too quick to try and make it slide to easily. loose panels rattle and can often move with vibration. Yes, Yes I hear you say but I can't open the window! Well when sliding the window to another position rather than using brute force that will snap the applied push pad off try flexing the window outwards as you slide it. Think you'll find it now works fine and has two advantages. in that when you have positioned it it will stay there and when closed and parked up it offers quite a difficult operation for a potential thief. He won't think to flex the panel prior to sliding it!
I had considered that a non-opening passenger side window would have slight 'anti-theft' benefits! Also, it's stops Mrs Tykester opening it and abusing other motorists, and cyclists… with whom she has particular issues!
The positives are outweighed by the negatives though, so I am committed to having a more determined effort this weekend. I'll throw everything at it - silicone lube (got some which I use on the rubber seals), a little heat with Mrs T's hairdryer (if I can get it out of her sight - it's an expensive Dyson one!) and as much flexing as I dare, all whist using the blunt knife again which will probably be easier to apply a little force with compared to a credit card.
I shall report back...
1999 4/4
Vespa PX125
Royal Alloy GP125MT
Sounds like you could hoover the garage floor at the same time. innocent
Simon
2002 4/4
2021 Audi A1 sport
