3 members (RichardV6, Hamwich, TeddyAds), 280 guests, and 42 robots.
+8Rich 92
Posts837,278
Page 3 of 4 1 2 3 4
Originally Posted by Adam12
Fantastic! The cars seem to have a lot more ground clearance and suspension travel than my 2019 +4!
I seem to remember reading that the three musketeers had the ground clearance of their Morgans increased. Perhaps even ex works.
2003 Morgan 4/4 2-seater
Originally Posted by Image
It's like when you buy a car and suddenly start seeing loads of them passing on the road! šŸ™‚
This popped up on my FB .... French guy on his way to Classic Le Mans towing his caravan with a 1965 4/4
Seems towing is more common than we think! šŸ™‚
The owner of this "attelage" as we say in french is my friend Xavier Delaunay, he was on his way to Le Mans as he was racing on "Plateau 1" on a Morgan 4/4 1938 (car N°59) with the owners of the car, Bouleau father & son who are Morgan agent (Welcome Automobiles) near Tours.
Happy Morgan +8 (2001) owner
BMW 435i - X Drive
Royal Enfield 500 EFI
Royal Enfield 650 Interceptor
1 member likes this: Image
Jens #834658 03/12/25 09:17 PM
You are right, the ground clearance was increased about 3 to 4 cm and a protective armour has been fitted under the engine, gearbox and rear axle. All the modifications where made at the Factory at Malvern
BMW 435i - X Drive
1 member likes this: Jens
The ride height was lowered when they replaced the rear lever arm system sometime in the 90's.
If you want to increase your front ride height and give greater clearance for sump, gearbox etc. then when replacing the front king pins etc...put the SSL RS Front Suspension kit on and that allows you to raise the front end by about 1'', plus it give you a more compliant front end compared to the standard setup.
22 Plus Four KIMI
12 Plus 4 Sport OZZY
08 Roadster FELIX
06 4/4 70th LOKI
77 4/4 SEAMUS
85 4/4 MOLLY
Jacques ... thanks for the info on the Morgan attelage .... do you have any pics of the car #59 at Le Mans?
I have no pictures of mine but you can see the car here (it's from 2023 edition but it's the same car : DOH31 registration plate)
And here (click on the link) during the 2025 edition
LMC 2025 - Plateau 1 virage Dunlop car 59
BMW 435i - X Drive
Best Morgan (s) trailer from my friend Didier Coste thumbs
BMW 435i - X Drive
Jaques ... his caravan tow-car the modern BRG and the flatrad racer the traditional BRG ... lovely pair of cars!
I do love the look of the flatrads ... Morgan should have kept it as an option! šŸ™‚
The Midsummer grille did give a little nod I thought, to the Flatrad design...if you half close one eye
Might be a minority opinion, but when it comes the Midsummer's styling I prefer to close both eyes!! šŸ˜†
Page 3 of 4 1 2 3 4
