0 members (),
238
Topics49,841
Posts837,323
Posts: 1 |
Does anyone know if you can retain the mechanical rod clutch linkeage when fitting a type 9 into a 74 crossflow ?
Posts: 6,667 Likes: 433
Posts: 6,667 Likes: 433 |
Yes, when mine was done by SiFab, he kept the rod. Not the best photo - but you may get the idea ![[Linked Image]](https://www.tm-img.com/images/2021/10/15/IMG_20211015_155818.md.jpg)
Posts: 809 Likes: 59
Posts: 809 Likes: 59 |
I couldn't get it to adapt to T-9 in my '73. It may have been that the bell housing I got wasn't built for it. I went with a hydraulic set up and it works nicely. It seems a lot simpler that way. More linkage means more to go wrong, and more to lubricate.
Posts: 5,586 Likes: 603
Posts: 5,586 Likes: 603 |
My '74 crossflow has a cable operating it ... the joys of Morgans! 🙂
Not wildly enamoured with it ... I wonder what it would take to change to Rod Operation? ... might investigate that over Winter.
Can take some better pics, but it's a really simple set up. Easy to set up and twea
Posts: 27 Likes: 4
Posts: 27 Likes: 4 |
When I converted my ‘71 4/4 in the mid 1980’s I tried hard to keep the original rod operation, but found the new T9 bell housing forced misalignment between the pedal rod bulkhead exit and the clutch arm. This did not seem sensible so moved over to a cable operation which has been totally reliable, and has covered some 70,000 miles now.
Posts: 17 Likes: 1
Posts: 17 Likes: 1 |
I was very interested to see TBM's rod operated set up, more pictures or drawings please. I have never been happy with Morgan's cable operated system, nasty piece of engineering which gives barely enough separation at the clutch. As I have the engine out at the moment I have been considering a hydraulic system with a concentric slave cylinder, but it is an expensive solution, pity Simon is not still around.
1970 4/4 1970 MF140
1 member likes this:
Graham, G4FUJ |
Posts: 17 Likes: 1
Thankyou very much TBM, that is definitely worth a try.
1970 4/4 1970 MF140
TBM |
