2 members (+8Rich, Mr K),
365
99
Topics49,859
Posts837,483
Posts: 142 Likes: 28
Posts: 142 Likes: 28 |
https://www.talkmorgan.com/ubbthreads.php/topics/651929/9The last posting on this subject was Sept, 2020. Has this changed at all, has anyone solved the problem of no tonneau cover for CX chassis cars? In winter when out solo in dry weather, I like driving with a tonneau cover over the rear and passenger side, and the hood down. Not possible?
Plus Six '75 Commando 850 '76 CB750K6
Posts: 5,465 Likes: 171
Posts: 5,465 Likes: 171 |
I am not convinced you can fit a foot locker in a CX. I believe that the fuses and ECU's are in the passenger footwell. Well worth checking before ordering one.
Posts: 3,850 Likes: 400
Posts: 3,850 Likes: 400 |
I am not convinced you can fit a foot locker in a CX. I believe that the fuses and ECU's are in the passenger footwell. Well worth checking before ordering one. Thanks for pointing that out, I need to check it out further.
22 Plus Four KIMI 12 Plus 4 Sport OZZY 08 Roadster FELIX 06 4/4 70th LOKI 77 4/4 SEAMUS 85 4/4 MOLLY
Posts: 27,810 Likes: 749
Posts: 27,810 Likes: 749 |
The fuses are behind a panel in the passenger footwell. You can make some space behind the rear panel. https://www.talkmorgan.com/ubbthreads.php/topics/814172/1I had Shaun at Allon White fit a tonneau which works perfectly. ![[Linked Image]](https://tm-img.com/images/2024/09/14/20240914_140849.jpg)
John,
Thanks for posting a photo. That looks good. I hadn't realised the Four has a double H/L brake light. Will need to see if they can accommodate a single centre light.
Could I ask, how is the cover fitted at the front and does it fold OK behind the driver's seat when unzipped?
Martin
Some P4 have the cobra. AW can sort out whatever you have. It is the usual 3 lift a dot pegs screwed into the crash roll at the front & then pop studs on the doors, just like the trads.
Posts: 526 Likes: 85
Posts: 526 Likes: 85 |
JI hadn't realised the Four has a double H/L brake light. Will need to see if they can accommodate a single centre light. Some Fours have a spare wheel, and therefore the single H/L brake light would be obscured. They therefore have either a Cobra or the twin H/L brake light. There'll be no issue with accommodating a single light.
Plus Six "Rachel" Volvo C40
Unfortunately, Paul is correct, the footwell locker doesn't work in a CX. And the centre console is around £750, that's not cheap for what is a limited amount of storage and somewhere to rest your left arm!
