2 members (yobtaf, BHV), 305 guests, and 40 robots.
Topics49,860
Posts837,486
Jonny72
#835724 24/12/25 07:47 AM
MartO Offline OP
https://www.talkmorgan.com/ubbthreads.php/topics/651929/9
The last posting on this subject was Sept, 2020. Has this changed at all, has anyone solved the problem of no tonneau cover for CX chassis cars?
In winter when out solo in dry weather, I like driving with a tonneau cover over the rear and passenger side, and the hood down. Not possible?
Plus Six
'75 Commando 850
'76 CB750K6
MartO #835726 24/12/25 08:16 AM
https://www.allonwhite.co.uk/shop/category/morgan-interiors-and-hoods-morgan-tonneaus/full-tonneau/
I believe John V6 has a tonneau cover and Allon Whites could be the guys to go to. I'm sure John will put a picture up of the tonneau cover.I'm not sure where the different attachment points are on a CX tonneau cover.
Due to the lack of cubby hole,s pockets etc in a CX I'm considering an arm rest https://www.allonwhite.co.uk/shop/category/morgan-interiors-and-hoods-interior-trim-items/arm-rest/ and a foot locker https://www.allonwhite.co.uk/shop/category/morgan-accessories-footlockers-for-morgans/
22 Plus Four KIMI
12 Plus 4 Sport OZZY
08 Roadster FELIX
06 4/4 70th LOKI
77 4/4 SEAMUS
85 4/4 MOLLY
1 member likes this: MartO
MartO #835730 24/12/25 09:39 AM
MartO Offline OP
Brilliant, thanks.
Plus Six
'75 Commando 850
'76 CB750K6
I am not convinced you can fit a foot locker in a CX. I believe that the fuses and ECU's are in the passenger footwell. Well worth checking before ordering one.
Costock, UK
Disco 5
Paul F #835738 24/12/25 12:16 PM
Thanks for pointing that out, I need to check it out further.
22 Plus Four KIMI
08 Roadster FELIX
06 4/4 70th LOKI
77 4/4 SEAMUS
85 4/4 MOLLY
MartO #835742 24/12/25 12:42 PM
The fuses are behind a panel in the passenger footwell. You can make some space behind the rear panel.
https://www.talkmorgan.com/ubbthreads.php/topics/814172/1
I had Shaun at Allon White fit a tonneau which works perfectly.
MartO #835747 24/12/25 01:36 PM
MartO Offline OP
John,
Thanks for posting a photo. That looks good. I hadn't realised the Four has a double H/L brake light. Will need to see if they can accommodate a single centre light.
Could I ask, how is the cover fitted at the front and does it fold OK behind the driver's seat when unzipped?
Martin
Plus Six
'75 Commando 850
'76 CB750K6
MartO #835753 24/12/25 02:20 PM
Some P4 have the cobra. AW can sort out whatever you have.
It is the usual 3 lift a dot pegs screwed into the crash roll at the front & then pop studs on the doors, just like the trads.
MartO #835756 24/12/25 02:55 PM
Originally Posted by MartO
JI hadn't realised the Four has a double H/L brake light. Will need to see if they can accommodate a single centre light.
Some Fours have a spare wheel, and therefore the single H/L brake light would be obscured. They therefore have either a Cobra or the twin H/L brake light. There'll be no issue with accommodating a single light.
Plus Six "Rachel"
Volvo C40
Unfortunately, Paul is correct, the footwell locker doesn't work in a CX. And the centre console is around £750, that's not cheap for what is a limited amount of storage and somewhere to rest your left arm!
Plus Six "Rachel"
Volvo C40
