0 members (), 260 guests, and 43 robots.
Topics49,860
Posts837,486
Jonny72
#835945 28/12/25 03:22 PM
Hi all, hope everyone has had a great Christmas.
I'm looking to buy a wooden gear knob from 'built by basil'. does anyone know the correct thread size, I assume it's the standard MX5 one 10mm x 1.25?
Cheers,
Martin
Martin W #835960 28/12/25 06:47 PM
My 2012 car was 10 x 1.25.
Late 2012 M3W
Martin W #835970 28/12/25 09:39 PM
Thanks, does it just unscrew do you know?
Martin W #835975 29/12/25 12:30 AM
Thinking about this I decided to check the actual parts to make sure I'm remembering this correctly. When I received the car (used) it had an aftermarket shift knob (a #3 billiard ball!) which has the M10-1.25 thread. The original Morgan supplied knob, which I have, appears to have no threads at all, just a rubber internal sleeve which is approximately 10mm in diameter. I don't have the original shift lever which I swapped out when I converted to a forward shifter position years ago. My current shift knob is M10-1.25 thread.
So I can't definitively say how your gear knob is retained, as I don't recall what it took to remove the original shift knob. But a threaded knob will have thin lock nut under the knob which keeps it from spinning or coming loose.
Sorry about the confusion.
Edit: an update with a video link to Phil Bleazy doing an engine removal. The bit about removing the shift knob begins about 23:30 minutes in.
Late 2012 M3W
Martin W #835986 29/12/25 09:33 AM
My 2013 car has the more forward mounted gear change and has exactly the same system as shown in Phils video, the 3 grub screws and plastic sleeve. As far as I know this is "standard" and any threaded gear change is a modified one.
Martin W #836039 29/12/25 09:59 PM
So what is under the plastic sleeve?? Threads?
Late 2012 M3W
Bitsobrits #836045 30/12/25 08:58 AM
It's a time since I removed it but from memory, no threads, just a plain shaft. It's held on with the 3 grub screws through the collar.
planenut #836046 30/12/25 09:30 AM
Like this:
Martin W #836822 13/01/26 01:57 PM
Martin,
you will find below all the useful information regarding my purchase of a Gear Knob from Basil coffee :
https://www.talkmorgan.com/ubbthreads.php/topics/799359/1
There are no set screws to fix the knob, just a first threaded aluminum ring, which serves as a locknut. idea
[Linked Image] [Linked Image]
Lille - France
Plus Four 2024
Martin W #836843 13/01/26 09:56 PM
Thanks for that, I've got the original one off now and it was threaded the same as yours, just waiting for my new one to be made, yours looks awesome.
