15 members (MATTMOG, TBM, Winigo, John V6, hillclimber, deano, Mark+4, Alistair, BobtheTrain, DaveW, IcePack, Morganmike, Socalm3w, TeddyAds, sewin), 349 guests, and 64 robots.
+8Rich 76
Topics49,859
Posts837,517
Jonny72
#839297 04/03/26 09:06 PM
Hi I have an 1800cc Black Top Zetec engine I thank its based in the Ford Focus Can any please give me an idea when the fuel pump earth would or is likely to be, The pump sender is working confirming the amount of fuel in the tank but again the pump its self does not work but connect an auxiliary power to the pump and the pump runs.
Any advise would be most apprecated.
kevin smith #839302 04/03/26 10:20 PM
Check the relay first…
https://www.gomog.com/allmorgan/4~4%20Focus%20Schematic%20Front%20wiring%20diagram.pdf
kevin smith #839308 05/03/26 07:15 AM
Try replacing fuel pump relay as suggested and always carry one as a spare. British made Durite is the go to brand.
1 member likes this: Luddite
kevin smith #839327 05/03/26 11:19 AM
Richard, thanks for the relay info, though wonder if there might be any advantage to using a relay with a diode across the contacts to perhaps extend it`s lifespan...? Similar thinking might be applied to the starter motor relay...thinking the effects of back EMF from an inductive load..?
kevin smith #839333 05/03/26 11:41 AM
I use Bosh ones with a diode. I’ve chucked an image in the Morgan Photo Gallery.
Worth buying them in bulk as it’s annoying to have to wait and get one/some when you need them.
They also change part numbers from time to time as the design improves.
Luddite #839384 06/03/26 07:23 AM
Apologies yes, posted in a hurry blush. Diode equivalent below.
Luddite #839387 06/03/26 08:34 AM
You raise an interesting issue with your post George. Clearly the relatively low current cube shaped starter relay, matching others on the car, should have diode protection for ECU and associated electronics. What of the piggy back starter solenoid though? This has two coils each much larger than the relay mentioned above with consequently greater back emf spikes but no diode protection. Video below explains the need for the two coils.
AI answer suggests that circuit design mitigates these spikes but how I wonder thinking
kevin smith #839388 06/03/26 08:46 AM
I'll stick my portable Philips Scope on there one day when I get bored and tell you if I can be arsed.
Probably not, if it's working don't piss about inventing problems saw me through 43 years of 99.91% Transmission availability record for Decca Marine Navigation on continuous operations unlike Beeb and others with limited transmission time innocent
There are those that do and those that teach or preach is another take away from my lucrative career rofl
Another reason I will never comment on Electronic/Electrical issues on here is that you are only subject to a novices interpretation of the fault condition, never a good thing. If you don't know anything seek a local expert and put some money their way instead of blowing something else up.
I won't touch building as I don't like or understand concrete and blocks as they bore the arse off me too. I have builder friends that do and employ them instead.
So I find TM amusing at times to say the least amid the pure nuggets from Arwyn thumbs
kevin smith #839391 06/03/26 09:32 AM
RichardV6, many thanks for posting the vid. As they say every day is a school day, in that I had no idea that the starter solenoid design had two windings, though at least I can can understand why. I have stripped and repaired a few starters, and their solenoids, even down to reversing a burned and pitted copper disc in the solenoid, to extend it`s servicability, and never gave it a thought that there might be two coils within the solenoid.... Duh..!
My question re the possible advantage of a diode across the contacts in the relay, was related to the possibility of the diode quenching the back emf from the solenoid coil, when the relay contacts broke the circuit, thus perhaps the addition of a diode would extend contact life...and were that the case, the relay failure rate might be reduced..?
Also thanks for posting the pic of the relay with the diode across the coil, which from your description is there to protect later Morgans than mine, on which numerous functions are controlled by an ECU..
kevin smith #839399 06/03/26 12:25 PM
Thank Gents for your replies, I have ordered a replacement relay as suggested, will let you know how i get on when its delivered. thanks again
