1 members (Bitsobrits),
334
32
Posts837,276
Posts: 534 Likes: 101
Posts: 534 Likes: 101 |
I’m lost which is normal for me but isn’t my wife’s husband you !? Lost in translation ….? My wife’s old husband ? MM
Posts: 3,824 Likes: 69
Posts: 3,824 Likes: 69 |
I think he's referring to himself...comic effect.
Posts: 14 |
My wife's husband - love it!
Posts: 8,663 Likes: 489
Posts: 8,663 Likes: 489 |
Thinking about all the old cars over the years (and one present) that have had a clothes peg to set the choke ... this made me smile 🙂 ... there will be people buy them for sure!! ![[Linked Image]](https://www.tm-img.com/images/2026/03/17/FB_IMG_1773750755922.jpg) K I still use one, but certainly not some fancy machined from billet alloy jobbie
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
A choke! That brings back memories. I even remember winter starting after turning the engine with the crank handle to "loosen" the engine. I also had an Austin Maxi with a pull cable connected to flaps to block part of the rad to get faster warming up in winter.
Posts: 5,437 Likes: 131
Black Rat Charter Member
Posts: 5,437 Likes: 131 |
Remind me of a story I heard years ago. A lady repeatedly complained to the garage that her car would not run smoothly when warm. After checking everything several times the mechanic said take me out and show me the problem. So the lady got in pulled out the choke and hung her handbag on it!!! Problem solved! Some years ago a lad took his girlfriend and two others for a flight taking off from Southend (SND) airport as the aircraft started to lift the pilot's girlfriend pulled out the carb heat and hung her handbag on it, the aircraft crashed (due to reduced power) fortunately nobody was seriously hurt.
Posts: 6,666 Likes: 433
Posts: 6,666 Likes: 433 |
Part of my morning routine - a little tickle of choke and off. My MG still has a working 'twist lock' - (although I am gulty of occasionally leaving it on). The lock has failed on the Mog, but I'm going to replace over Easter. I am definitely a pegging free zone
Posts: 37,403 Likes: 977
Posts: 37,403 Likes: 977 |
1 member likes this:
Jon G4LJW |
Posts: 6,954 Likes: 115
Posts: 6,954 Likes: 115 |
Jon G4LJW |
You know Bob - the old Bog graffitti meat and two veg...in the ballot box area
