1 members (Bitsobrits), 334 guests, and 32 robots.
+8Rich 94
Posts837,276
#841035 08/04/26 01:21 PM
moggin Offline OP
I'm negotiating with a Morgan dealer in Florida on a 2025 Plus Four. It does not have the usual factory installed pre-delivery luggage rack mounting hardware. Has anyone added that hardware after the car was built? If so, how difficult and how expensive? Any references to a shop experienced in the procedure? Thanks!
You can't beat a man at his own game.
As long as you have the triangular brackets near the exhaust it is easy.
I have ringed the bracket in blue in this photo. If you don't have it I guess you have to cut the valance & weld it on both sides
This is my PlusFour in build, the brackets are mounted on those black "studs". I don't know if these studs are present without the luggage rack equipment? It is easy to check if you look underneath the car!
Ruut Bianchi
https://www.talkmorgan.com/ubbthrea...ge-rack-bracket-reinforcement#Post788887
This is a link to a post with pictures which tell the story! Excuses for the distortion in my picture (a TM-img thing..... )
Ruut Bianchi
WJH Offline
It seems that the US (or maybe it's just CA) don't let Morgan ship cars with racks fitted. Make sure you get a full price from your dealer that includes an out of the door price. I got a bit of sticker-shock when I picked up my Mog in February - the rack (after fitting) ended up costing around $2800.
You might want to give Williams Automobiles in the uk a ring - their friends at Librands make a nice rack and you could discuss it with them. You might want to consider the librands rack with a slot for the window panels, although if you have a spare wheel this “stacks” rather high and can block visibility.
