6 members (Rovert, JMcL, MartO, TeddyAds, IcePack, How), 311 guests, and 46 robots.
+8Rich 92
Topics49,838
Posts837,296
#841085 09/04/26 10:02 AM
Took Roadster out garage for a run only to notice both wings has large bubbles under the paint work. They have originated from the locating pins of the foot rails.
The car is 7 years old. Should this of happened. Any advise best way forward please.
Phil1953 #841089 09/04/26 10:30 AM
Rog Offline
There’s a possibility it may not be corrosion… If it’s like mine, the apprentice overtightened about 50% of the foot rail fixing screws and distorted the aluminium. It looks similar to a corrosion bubble but it’s nothing to worry about. Mine is just another Morgan feature ooo
Roger
Phil1953 #841092 09/04/26 12:17 PM
Very common. Slightest thinning of paint around the oversize tread holes, which allow water to be trapped, and it starts. I removed my treads to check and found very slight onset of corrosion. Hand touched up paint underneath and refitted with plenty of silicone grease and nylon washers between treads and bodywork.
1 member likes this: Lola_4/4
Phil1953 #841103 09/04/26 05:29 PM
Many thanks for your thoughts. DO you think this should be covered under warranty?
Phil1953 #841104 09/04/26 06:47 PM
Agree with Richard. I used waxoyl on mine to stop galvanic corrosion. You need to take it appart and treat the holes and bolts
Phil1953 #841107 09/04/26 07:52 PM
Not at 7 years old
