1 members (Saxonian),
218
Topics49,844
Posts837,360
Posts: 11 |
Took Roadster out garage for a run only to notice both wings has large bubbles under the paint work. They have originated from the locating pins of the foot rails. The car is 7 years old. Should this of happened. Any advise best way forward please.
Posts: 1,703 Likes: 35
Posts: 1,703 Likes: 35 |
There’s a possibility it may not be corrosion… If it’s like mine, the apprentice overtightened about 50% of the foot rail fixing screws and distorted the aluminium. It looks similar to a corrosion bubble but it’s nothing to worry about. Mine is just another Morgan feature
Roger 2011 Plus 4
Posts: 8,664 Likes: 408
Posts: 8,664 Likes: 408 |
Very common. Slightest thinning of paint around the oversize tread holes, which allow water to be trapped, and it starts. I removed my treads to check and found very slight onset of corrosion. Hand touched up paint underneath and refitted with plenty of silicone grease and nylon washers between treads and bodywork.
1 member likes this:
Lola_4/4 |
Posts: 11 |
Many thanks for your thoughts. DO you think this should be covered under warranty?
Posts: 27,807 Likes: 749
Posts: 27,807 Likes: 749 |
Agree with Richard. I used waxoyl on mine to stop galvanic corrosion. You need to take it appart and treat the holes and bolts
Posts: 8,671 Likes: 489
Posts: 8,671 Likes: 489 |
Many thanks for your thoughts. DO you think this should be covered under warranty? Not at 7 years old
