It happened again, on the way back from Spa I ended up among a gang of cycling terror/tourists who want to brave the course of Liège Bastogne Liège.
For more than 5 Km it went uphill shifting between 1 and 2.
And when I finally had been able to drive on again, I felt the spring of the clutch pedal snap just before Liège.
It has only been 13 months, 7 to 8000Km since the last time I replaced the spring.
There was so much play on the pedal that I did the rest of the route via the highway.
This was the cause of the play, axle half worn away.
![[Linked Image]](https://www.tm-img.com/images/2026/05/03/20260427_144301.jpg)
So, looking for a new spring and axle.
But Belmog, who has stopped in the meanwhile, only has a left spring in stock and no axle.
Morgan Belgium to the rescue
They are on leave until next week.
And we are leaving for the South of France next week, then only DIY can help.
![[Linked Image]](https://www.tm-img.com/images/2026/05/03/20260427_144432.1.md.jpg)
I made a new axle myself and the play on the pedal is gone, perfectly drivable without a spring.
During assembly I saw that the brake pedal also has a righthand spring but can also be provided with a lefthand spring.
![[Linked Image]](https://www.tm-img.com/images/2026/05/03/DSCN7534.md.jpg)
Got a left spring from Belmog and exchanged it with the clutch and everything is back the way I like it, although it was a bit hectic.
