4 members (thelastgizmo, TBM, +4competion, John V6), 343 guests, and 41 robots.
+8Rich 92
Posts837,284
#843024 09/05/26 08:52 PM
I will soon need to replace my coolant hoses (3.9 Plus 8), has anyone had dealings with Classic Silicone Hoses? They offer a set for this car but the guy is very difficult to contact - I got a quote from home but he’s since gone quiet on me. Are there any other supplies out there? I’ve tried Samco, ACT and Viper.
Mike H
Bourgogne Franche Comté
TBM Online Content
I used him several years ago - I think he makes everything to order, but I was lucky enough to get a kit off the shelf that he'd made for someone who hadn't paid.
If you are happy with the extra expense it's worth getting the smooth band clamps designed for silicone hose .... normal clamps can damage it.
Beware, whilst looking trick silicone hoses can be more troublesome to seal at connections. This because the material is slicker rather than sticky as with conventional rubber hose. I had a small weepage from the supplied silicone bottom hose extension when fitting an aluminum radiator. It was only eventually cured by doubling up on hose clips.
4 members like this: stefan s, Mick Annick, gomog, Luddite
Z
Z
Hi Mick
I purchased a silicon elbow for lower radiator to pump connection from this place
https://www.autosiliconehoses.com/
Regards Tony
1 member likes this: Mick Annick
Zach #843056 10/05/26 12:03 PM
Excellent link Zach! Silicone is indeed a better automotive coolant hose type than rubber. Rubber inevitably fails in many weird ways, and more so with cars that get stored for long periods. To reduce the number of junctions (wisdom Luddite imparted to me 25 years ago) one is best to buy your engine hose kit . Aesthetically, I admit to avoiding coloured silicone. I use black North Americans are different in seeing the engine bay as aesthetically important as the exterior.
While in the hose area, it should be mentioned that PTFE hose lines with braided stainless steel sheathing for petrol, oil, brake and clutch fluid, coupled with AN fittings (adding a couple at the bulkheads..thank you Lance) is superb for a number of reasons. BTW, they now come in a more discrete black nylon exterior covering the ss and that that makes them pass for rubber THESE products are infinitely strong and fireproof. They will also not all rip off in an impact. Their installation is not difficult once you figure how to attach AN fittings to such lines. However, most Morgan sellers (UK) will do the attaching for you for very little, but get the lengths right! L. (wryly)
L.
