1 members (Ian Wegg),
260
83
Topics49,847
Posts837,389
Posts: 2,360 Likes: 2
Posts: 2,360 Likes: 2 |
I use motul v 300 20/60 No problem
Posts: 580 Likes: 2
Posts: 580 Likes: 2 |
Wilson, is Motul oil designed for the S&S V twin? I believe "V Twin oil" as S&S suggests has ZDDP (Zinc) in it for the anti wear properties. Please correct me if I'm wrong. I always use Mobile One V twin oil--it says on the label for V twins For use in the south of France where the ambient temperatures can sometimes be over 40º, both Raphy and I wanted the extra protection of a 20W60 oil over a 20W50. When my car was working, I measured the oil temperature after a long hard run. It was around 110º. Whereas this is a problem for the oil lines that Morgan fit, which are only rated to 100º, it is fine for the oil, rated to 165º. I had a very helpful discussion with Motul's competition department. They felt that the 20W60 300V Le Mans oil was ideal for an air cooled engine, being operated in high ambient temperatures. Wilson PS During the rebuild, I have had an oil temperature gauge added, so I will keep a close eye on the oil temperature. If I feel it is getting on the high side, I will add an oil cooler to the return to the oil tank side of the system. The problem is a suitable location for the cooler. Down in front of the engine, is too vulnerable to parking idiots and in the grille gets no cool air. I think mounted on the side just behind the wishbones might be the best place.
Posts: 1,947 |
Wilson there has been discussion about fitting an oil cooler. Here is one thread. http://www.talkmorgan.com/ubbthreads.php/topics/373898/1Yes Aberdeenshire is cooler than South of France, sometimes that is a good thing, 24C is enough for me. Minus 10C is less good but not driving the M3W then. Tim
Posts: 580 Likes: 2
Tim,
I looked at that thread before my chassis failed. Fitting an oil cooler where the thread suggests down in front of the crankcase, would be very risky in France. There in rural areas, as where I live, many folks still park their rusty old heaps by "the contact method". No parking bleepers for them; the crunch of crumpling bodywork serves just as well.
Wilson
Posts: 28,894 Likes: 351
Posts: 28,894 Likes: 351 |
... the crunch of crumpling bodywork serves just as well.
Wilson I thought that was the parking method in most of France?
Posts: 508 Likes: 1
Dreiradschubser Talk Morgan Regular
Posts: 508 Likes: 1 |
Harley Davidson dealers in LeMans fitted my unit using 2bolts directly onto the mounting plate welded to the chassis. This was back in 2014.
It has been faultless ever since. I had the same repair one or two days after Dab of oppo in Le Mans, I was happy to get the last unit :), no problems since then Achim
Posts: 159 |
I get the impression that your rebuild is costing more than the original price of the vehicle!
Posts: 580 Likes: 2
I get the impression that your rebuild is costing more than the original price of the vehicle! Sadly I suspect you are correct. It is all "apparently" finished apart from the new HD regulator being wired up. Another forum member who has been assisting the garage with the rebuild (probably doing most of the work), is very kindly going to fetch me from my house in the second week of April to go and collect the M3W from beside the Paul Ricard circuit. We are then going on to lunch at the Hotel Ruhl just outside Marseille, where I think the best bouillabaisse in the world is served. Spectacular views as well towards the island with Chateau d'If on it (Count of Monte Cristo). Wilson
Posts: 8,667 Likes: 408
Posts: 8,667 Likes: 408 |
Thought I would awake this old thread rather than start a new one. The recommended replacement HD regulator rectifier (RR) for M3W seems to offer greater reliability especially if mounted to improve cooling however it appears to be also of the crude shunt type common even to current budget motorcycles. These simply dump excess alternator stator current to ground in order to maintain a battery friendly charge/float voltage around 14.4 volts irrespective of load from the electrics. This translates as the alternator running flat out all the time which itself produces excess heat as well as heat dissipated through the coollng fins of RR itself. I wonder therefore if anyone has retro-fitted a typically MOSFET controlled series type RR which simply switch the stator on/off at high frequency to maintain correct battery voltage. One such example is the Shindengen SH847 a popular retrofit on bikes, and rated up to 50 amps, stressing alternator stator less by essentially only taking current needed to maintain battery and power electrics, as well as running cooler themselves  Apologies if this is already common knowledge but couldn't find any reference to such in a search.
Posts: 786 Likes: 18
Posts: 786 Likes: 18 |
The Shindengen SH847 must be mounted on a thick aluminum plate of about 5 mm to dissipate heat and thermal paste between the two prevents it from overheating, personally I bought a Chinese copy for less money which I have not yet tried because I still have three new adaptable Harley type regulators in stock which are also made in China and as durable as the original regulator.
