Topics49,868
Posts837,638
Posts: 52 |
I have to replace the grill mesh in my 2025 plus four. Could someone please provide instructions? Thanks
You can't beat a man at his own game.
Posts: 8,683 Likes: 413
Posts: 8,683 Likes: 413 |
On the later trads the number plate box bolts hold the grill and its mesh up, supported by slots inside cowl at the top. Would start by removing them as I imagine CX cars would have similar mounting. Take care to note position of rubber spacers for re-assembly.
Posts: 52 |
Thanks Richard,
I removed the two bottom bolts to remove the license plate backing piece. Florida does not require a front license plate. I could only wiggle the bottom of the grill and mesh but not enough to center - or straighten - them in the cowl. What's holding them at the top? Are the bottom holes slotted so I can move them to the right to center them? The factory did a very poor installation job. And which rubber spacers are you referring to?
If I want to replace the mesh, what tips can you provide so I don't scratch the paint on the cowl's inner edges while removing or installing the new mesh? Thanks for your assistance.
Posts: 793 Likes: 144
Posts: 793 Likes: 144 |
Try using superglue to fix a thin rubber strip to the underside of the degreased cowl. Old bicycle inner tube works well.
Chris
2015 Plus 4 Silverlake Blue (2014 3.7 Roadster Crystal Blue) (2012 4/4 Sport Black)
Posts: 541 Likes: 7
Posts: 541 Likes: 7 |
Just mind you fingers, edges of the grill mesh can be very sharp.
