One little trick if your chassis strengtheners have a little hole on the top plate. Make sure it's clean and dry and apply a full circle bead of silicone sealant about an inch in diameter around the hole. When dry you can fill the well you have created up with ACF-50. This allows the fluid to flow into the potential space between the two plates without you standing around over many days trying to get some to flow into the hole.
