Morgan Aero 8
5 members (DPEvans, gmcn, Julian BB, Ian Wegg, Zach), 300 guests, and 59 robots.
+8Rich 81
Topics49,859
Posts837,504
Jonny72
Page 1 of 4 1 2 3 4
#85074 12/03/12 06:40 PM
mr_tony Offline OP
Mr Fezza
Mr Fezza
Max is in for MOT and annual service, so thought I wild mention what I am getting done, for those over owners out there..
1. Sort out drivere side door switch.
2. Check power steering pump - occasionally slow to work on start up.
3. Check door alignment. Think it's fine but good to be sure
4. Fit high speed stability blades under front spoiler. (kind of c shaped brackets that create more front downforce)
5. Check how to switch off passenger airbag.
6. Full service + MOT
Will update you later in the week when I collect.
Maxxed out!
mr_tony #85077 12/03/12 06:49 PM
Gone to Porsche
Gone to Porsche
that will be £976.21 Sir thank you hope to see you again
mr_tony Offline OP
Mr Fezza
Mr Fezza
wink I guess we'll see!
Compared to some things I've driven Morgans are usually sensible prices to look after though (touch wood)...
Maxxed out!
mr_tony #85120 13/03/12 07:03 AM
Saw the 'Max in SGT yesterday Rich, when I picked up my 3W. Service should be cheap, unless you buy that Bentley Le Mans Series! innocent
I must admit if I had anywhere to put it I could be sorely tempted, the condition is concours and the leather still smells new...
Brian
2014 Morgan SP1 (Rocket Red)
Aeroman #85146 13/03/12 10:55 AM
My last service for 30.000 kms, including oil change, coolant change, brake fluid change, some electric gremlins fix, came at 800 Euro or so
Interested to learn more about the stability blades
aeromax #85167 13/03/12 03:03 PM
You can get them from MMC, or I guess through your Dealer. Despite being just a couple of small bent bits of metal, which fit under the front wings, they do make a big difference to the handling at the upper end of the speed envelope! woohoo
Brian
Aeroman #85201 13/03/12 08:22 PM
Do you have any photo's of these?
No, but I could take some of them fitted?
Brian
Aeroman #85223 14/03/12 06:34 AM
mr_tony Offline OP
Mr Fezza
Mr Fezza
I'll ask the dealer if the can send some pics if they aren't fitted already...
Maxxed out!
Aeroman #85268 14/03/12 11:27 AM
Fitted is probably best.
Thanks
Page 1 of 4 1 2 3 4
