1 members (TBM),
270
38
Topics49,860
Posts837,486
Mr Fezza Talk Morgan Expert
Posts: 2,825 |
Max is in for MOT and annual service, so thought I wild mention what I am getting done, for those over owners out there..
1. Sort out drivere side door switch. 2. Check power steering pump - occasionally slow to work on start up. 3. Check door alignment. Think it's fine but good to be sure 4. Fit high speed stability blades under front spoiler. (kind of c shaped brackets that create more front downforce) 5. Check how to switch off passenger airbag. 6. Full service + MOT
Will update you later in the week when I collect.
-------------- Maxxed out!
Gone to Porsche Part of the Furniture
Posts: 4,333 |
that will be £976.21 Sir thank you hope to see you again
Posts: 2,825 |
 I guess we'll see! Compared to some things I've driven Morgans are usually sensible prices to look after though (touch wood)...
Posts: 7,363 |
Saw the 'Max in SGT yesterday Rich, when I picked up my 3W. Service should be cheap, unless you buy that Bentley Le Mans Series!  I must admit if I had anywhere to put it I could be sorely tempted, the condition is concours and the leather still smells new...
Brian
1970 Morgan Plus 8 - Moss Box (Indigo Blue) 2014 Morgan SP1 (Rocket Red) 2015 Morgan Plus 8 (Rocket Blue)
Posts: 98 |
My last service for 30.000 kms, including oil change, coolant change, brake fluid change, some electric gremlins fix, came at 800 Euro or so
Interested to learn more about the stability blades
Posts: 7,363 |
Interested to learn more about the stability blades You can get them from MMC, or I guess through your Dealer. Despite being just a couple of small bent bits of metal, which fit under the front wings, they do make a big difference to the handling at the upper end of the speed envelope!
Brian
Posts: 2,562 Likes: 89
Posts: 2,562 Likes: 89 |
Interested to learn more about the stability blades You can get them from MMC, or I guess through your Dealer. Despite being just a couple of small bent bits of metal, which fit under the front wings, they do make a big difference to the handling at the upper end of the speed envelope! Do you have any photo's of these?
Posts: 7,363 |
You can get them from MMC, or I guess through your Dealer. Despite being just a couple of small bent bits of metal, which fit under the front wings, they do make a big difference to the handling at the upper end of the speed envelope! Do you have any photo's of these? No, but I could take some of them fitted?
Brian
Posts: 2,825 |
I'll ask the dealer if the can send some pics if they aren't fitted already...
You can get them from MMC, or I guess through your Dealer. Despite being just a couple of small bent bits of metal, which fit under the front wings, they do make a big difference to the handling at the upper end of the speed envelope! Do you have any photo's of these? No, but I could take some of them fitted? Fitted is probably best. Thanks
