9 members (MogOnTheMove, Lordofthewings, PaulyG, Rex_tulips, John07, RedThree, linklaw, brownbaker, Richardllll), 320 guests, and 38 robots.
Adam12 68
+8Rich 67
John V6 59
9,215 Registered Users
New
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,365
Posts813,384
Members9,215
Rbt Aero8, Salmon, stevends
Page 2 of 4 1 2 3 4
le Asbo du Bling
le Asbo du Bling
Originally Posted By Mi3Wheeler
If you look at the most recent brochure for the 3 wheeler (page 8) it says 42 litres (~11.1 gallons).
http://www.morgan-motor.co.uk/mmc/downlo...ads_preview.pdf
The handbook says 55 litres from empty. I was down to 5% and managed to get about 25 litres in. So my guess is we all have different sized fuel tanks and I've got someone else's fuel gauge.
With regards mpg I'd guess it's somewhere between my Aero and my Prius if that helps. grin2
Slowly going green
If it is 42 litres, that is about 9.5 gallons in the UK.
Goodwood Drifter
Goodwood Drifter
I've don like 3 or even 4 refills,
never managed more than 26ltrs
handbook: 55ltrs
Steven
now: +fourLM62
AQM Offline
handbook: 55ltrs
Stupid question, but that's about half of the entire capacity. Does it only fill one of those rear tanks?
Maybe the fuel gauge is only conected to one of the two tanks. Eitherway, it should work properly!
The tanks are connected at the bottom, so it should empty both evenly at the same time. I don't think it is filling both very well, as the filler is only to the right side tank.
OK that was a stupid comment I made. Obviously they are connected, so it should make no difference.
Has anyone chanced running on past the empty (0%)on the fuel gauge just to see how far it will go before running out of fuel.
Looking at the two fuel tanks, they are about the size of a 5 gallon jerry can each, therefore substancially more than the 25 litres I was only able to put in with the gauge showing low. I suspect that the car still has quite a bit of fuel left when showing nearly empty.
Any one yet measured an accurate MPG figure ?
Has anyone chanced running on past the empty (0%) on the fuel gauge just to see how far it will go before running out of fuel.
I've only taken it down to about 10%, but even then around 25ltrs takes it up to almost brimming.
Brian
2014 Morgan SP1 (Rocket Red)
The old fashioned way to measure fuel was to start empty, then add a gallon at a time, and mark a dipstick.......which you then carried.
If you must run it dry then do it at home - much more convenient!
Page 2 of 4 1 2 3 4
