11 members (TalkMorgan, MartinB60, Montegue, Image, Tresco, JohnHarris, deano, Ricosan, MJF, Sir Percival, Julian BB),
251
103
Topics49,872
Posts837,694
Posts: 7 |
Yes I think a very heavy current draw is the key to the problem. I plan to take to an auto electrician to test current draw. Have replaced the thermostat switch thinking that may have been the problem.
N 2004 Plus 8
Posts: 145 Likes: 1
Posts: 145 Likes: 1 |
test the thermostat -bottom left of rad -for continuity might just be jammed shut.sounds more likely than three relays! OR you are getting a current to the relay from some other source?
Posts: 859 Likes: 1
Posts: 859 Likes: 1 |
If you disconnect the stat in the radiator, the fan should stop running. If it doesn't, then I agree with Chris that it must be getting the either an earth supply or 12v supply from elsewhere. I know that this may sound daft, but are you replacing the correct relay. If I remember correctly there are about 3 or 4 under the dash, which have different functions. I am sure the experts will advise.
Honda S2000 Lexus UX 250h Toyota Auris Hybrid
Posts: 1 |
Mr. Niel
Hello,hope you can help me to give me some advice about the morgan 2010 Vin # SA9EASSATAE004097 that im working now. Regarding the A/C condition. Its cooling but it's cutting off the a/c compressor very early and take time to engage again.
I would like to ask also the proper operation of two radiator fan and how it work especially when a/c is on?
Thanks in advance...
regards wilfred_bmw75
Posts: 859 Likes: 1
I wish I could help on that one. To be quite honest the A/C is not that efficient and is basically a cooler bolted to the heater air intake. It does cool but not that i have noticed the effect that much. I suspect that the two fans on the radiator are switched according to the load required for cooling. i.e if its a hot day, both fans will run. I would certainly have the coolant level checked in the system. It maybe that there has been a slight leak and the compressor does not have enough gas in the system to run properly. A good vehicle A/C company will check and top up as necessary. I hope that this is a little help, and I am sure someone on TM is a more competent A/C expert than me. Neil
PS - Welcome to Talk Morgan
