7 members (JMcL, aerotaff, BobtheTrain, Zach, davewhite, Pipmac, AlyMatt),
270
36
Topics48,337
Posts812,923
Members9,203
Posts: 1,664 |
Charlie, Former Editor Morgan Owners Group - Great Lakes
Posts: 3,827 Likes: 4
le Asbo du Bling Talk Morgan Addict
Posts: 3,827 Likes: 4 |
As promised Width 155mm. Height. 190mm. Length. 305mm Charlie I've given you the measurement in the Euro rubbish we have to use, hopefully we won't end up with a shuttle style problem and you get a box big enough to fit a 3 wheeler in.  .
Slowly going green
Posts: 1,664 |
Thank you again!
I took 4 year of mechanical drafting so I am decent enough at conversions from Euro-rubbish to American-gibberish.
(For those who are not good at it and want to know it roughly equals 6 x 7.5 x 12 inches)
Dam, I thought that would keep you going for a while
Slowly going green
Posts: 1,664 |
Similar roots, but at least you have the metric system... what do we have? exactly! Who knows? nobody, that's who. United States customary units, because, "The United States is the only industrialized nation that does not mainly use the metric system in its commercial and standards activities..." this calls for a United States customary units are a system of measurements commonly used in the United States. Many U.S. units are virtually identical to their imperial counterparts, but the U.S. customary system developed from English units used in the British Empire before the system of imperial units was standardized in 1824. Several numerical differences from the imperial system are present.
The vast majority of U.S. customary units have been defined in terms of the meter and the kilogram since the Mendenhall Order of 1893 (and, in practice, for many years before that date). These definitions were refined in 1959.
The United States is the only industrialized nation that does not mainly use the metric system in its commercial and standards activities,[3] although the International System of Units (SI, often referred to as "metric") is commonly used in the U.S. Armed Forces, in fields relating to science, and increasingly in medicine, aviation, and government as well as various sectors of industry. http://en.wikipedia.org/wiki/United_States_customary_units
Posts: 1,789 Likes: 3
Posts: 1,789 Likes: 3 |
25.4mm to the inch and 40 thou to the millimetre. I worked for an American engineering company for 15 years and all measurements were in imperial. We even had to convert European customers metric measurements into imperial before machining the parts! Happy days.
Posts: 1,664 |
Mr. asbojohn, if I could bother you once more about this ammo box topic. In my searching I found WWI ammo boxes, brass hardware on fine crafted dovetailed jointed wooden box with a brown leather handle. The issue is they are slightly larger in 2 of 3 directions and I was wondering if you could let me know if there was ample room for this size box.
Would 12 11/16" X 4 1/2" X 8" fit? LxWxH (322.25 x 114.3 x 203.2 mm)
Charlie,
The issue will be how is it hinged, and how does the lock work.
Mine has space around it but it needs space to hinge upwards, and the lock mechanism has what I an best describe as swivel which needs space.
I'll take some pictures tomorrow for you.
Slowly going green
Posts: 1,664 |
It is hinged similar to the one that you have and the latch seems to require less space to operate. To unlatch, it seems you push down in the center of the latch on the top of the box and it unhooks on the slender side. These are 2 different boxes, but it gives you a good look at the latch and hinge:
Posts: 1,664 |
