0 members (), 271 guests, and 43 robots.
+8Rich 89
Topics49,841
Posts837,323
Christoph
Thread Like Summary
BigLes, Graham, G4FUJ, RichardV6
Total Likes: 10
#820726 03/31/2025 7:23 PM
by BigLes
BigLes
My recently acquired Roadster has a strange mechanical noise when I push the car out of the garage. It sounds to me like a Universal Joint at the front end where it connects to the gearbox. I know the 3.7 engine is mated to a 6-speed transit box, and it seems the Transit uses a flexible coupling to connect to the propshaft (on a Transit) - does anyone know if this is also used on the Roadster? I've checked the prop shaft connection to the diff and that is all sound, but when I rotate the prop shaft (with the car in gear) I can feel some play at the front end. I'd be surprised if the front UJ has gone as the car has only done just over 10k miles. Is it the sort of thing that could go if the previous owner was a bit heavy with the dropping the clutch when pulling away?
I can't get the car into my local Morgan specialist until the end of April so any advice would be most welcome in the meantime. I'm not sure if I should drive the car in this state?
Liked Replies
#820789 Apr 1st a 04:09 PM
by DaveW
1 member likes this
#820818 Apr 2nd a 07:04 AM
by Arwyn Williams
Arwyn Williams
If you can get the propshaft out, I'd recommend taking it straight to a propshaft specialist.
Had a propshaft rebuilt recently with new uj's and then balanced for less than 60 quid.
Had a new propshaft made up for 150 quid which was less than the 350 plus VAT that the factory wanted!
Arwyn
1 member likes this
#820821 Apr 2nd a 07:26 AM
by John V6
I found the post. Here you go.
http://www.talkmorgan.com/ubbthread...-get-access-to-a-3-7l-roadster-front-ujs
1 member likes this
#821725 Apr 16th a 07:09 AM
by RichardV6
I used this Les - click for source - you will need two bottles as despite what manual says mine took 1.6 litres with car level on ramp.
It's suitable for LSD diffs and contains a friction modifier. Been in for a few years now and it cured the clicking I was getting when maneovering on full lock. Likely better than adding pure friction modifier into existing dirty oil. Be aware there is an NS suffix variant for racing which doesn't contain the needed friction modifier.
I used my Draper hand operated gear oil pump from below. This avoids spill when filling from above and has a convenient hook on end of pipe for attachment to filler hole.
1 member likes this
#821729 Apr 16th a 08:52 AM
by Roady
Roady
replacing the oil is a must at 6 years or 100k miles. Obviously the age is going to arrive before the mileage for most Morgan owners. I had such bad 'clunking' after twelve years that I had to get out the AA to ferry my car to the local dealer. They could find nothing wrong but I suspect that if they had replaced the oil instead of just topping it up when servicing the car I would not have had the problems I faced.
1 member likes this
#820883 Apr 2nd a 08:46 PM
by CooperMan
Originally Posted by BigLes
It's a 2018.
Here you go Les, couple of shots of the 3.7 gearbox from a 2018 build (Dave's photos are from a 3.0)
Access will be difficult to that front output coupling flange / propshaft bolts
1 member likes this
#821791 Apr 17th a 07:58 AM
by RichardV6
This oil is 75W90, the GoMog site suggests 80W140?
It probably doesn't make that much difference Les but I would rather stick with the factory manual stating 75W90 for our Roadsters.
1 member likes this
#821845 Apr 17th a 05:09 PM
by Deejay
Deejay
Fair comment Doug although Les does have a 3.7 Roadster. The universal factory manual for the runout Classics makes a distinction for them in that the thinner rear axle oil is recommended. I understand the Plus 4's also have a BTR axle albeit higher numerical ratio and was told at least some came with LSD confused2. TBH the fact that the Redline is full synthetic likely compensates and you have the advantage of less drag. I will stick with what works for me and continue to recommend it for Roadsters.
Thanks for that. I never realised the 3.7 was different. Certainly my handbook of 2011 shows the same oils for all models.
Anyway, as I have always said “Any oil is far better than no oil!” 🛢️
1 member likes this
#822955 May 4th a 07:03 AM
by RichardV6
Yes the play is not only normal but required for correct meshing of pinion to crown wheel.
As a side note you will notice when both rear wheels off the ground one wheel will turn the other when LSD present. A useful check for maybe Plus 4 owners if they are unsure whether one fitted or not.
If LSD is present it's worth mentioning during MOT. It's not unknown for rear brake test to destroy the clutches!
1 member likes this
#822958 May 4th a 07:11 AM
by John V6
Well done. Glad we could help.
1 member likes this
