I wonder if any of you have encountered these issue's before and could share your wisdom?
1) Hazzard lights... My indicators work perfectly on all four corners, however I have noticed my Hazzard lights only blink on one side! Does the Hazzard have its own relay or is this likely to be a hazzard switch issue?
2) If I switch off the ignition and remove the key with the main light switch on, the rear tail light stays on until i turn off the light switch, i'm assuming that this is not normal?
Any Ideas?
