7 members (MATTMOG, Mogdavid, deano, TeddyAds, JMcL, Bunny, Mark+4), 337 guests, and 87 robots.
Topics49,849
Posts837,415
DazMog, The Impaler, tlchzj79
Page 5 of 24 1 2 3 4 5 6 7 23 24
#678918 20/12/20 08:45 AM
Boat build
Another experiment in photo posting, this photo was taken yesterday, if this works I will add earlier pictures of the build and bore you all.
Fantastic, it worked, now I can add earlier pictures if there's any appetite for them out in TM land. I might even do it there's not.πŸ˜‚
Gordon Duguid
235 Comments
Gordon D #680028 27/12/20 05:13 AM
Originally Posted by Gordon D
...when the only skill you have is hitting things with a hammer.πŸ˜‚πŸ˜‚πŸ˜‚
Which is usually infinitely more useful! smile
miles of smiles
miles of smiles
When I get stuck , a little voice in my head always says β€œ use the force, Ewan , use the force”
I then spend the next few hours repairing what I broke doh
Gordon D #680035 27/12/20 09:24 AM
Whilst looking for the hull turning footage I came across these. This is the scarf jointing process for the plywood I mentioned in earlier posts.
The two sheets are placed in the jig one on top of the other, stepped by the length of the joint, machined, then the top sheet is flipped and the two or three and a half in my case glued together using cascamite.
Long lengths of wood for the hull were also created using this method.
Here's the joints machined and ready for gluing.
This is the scarf jig I made to create the beveling on the sheet ends.
The majority of the ply was removed with a power planer.
Then finished off with sandpaper.
Gordon Duguid
Gordon D #680052 27/12/20 11:05 AM
Thanks again for the update Gordon fantastic watching your time lapse progress, love the pot belly stove in the wee corner.
Your skills really are exceptional.
Gordon D #680062 27/12/20 12:06 PM
This is great stuff. Following with extreme envy of your skills and patience.
BTW - it's a long time since I last used Cascamite.
Costock, UK
Disco 5
Gordon D #680068 27/12/20 01:10 PM
Great project, attached are some pictures of my steam launch build, strip cedar planked.
https://www.tm-img.com/album/zuSc
Regards
Gallanach #680071 27/12/20 01:48 PM
Regards
That looks fantastic, do you have more photos and details of the build?
That's a project that would be well worth its own thread, I'm sure others would enjoy it as well.
I've spent this morning viewing the hull turning footage, there's around 40 minutes worth but I really should edit it and create something more watchable. There's a wee bit of bad language in places and a few builders bums on show pantsdown
The photos are not very good but I'll post some for viewing until I get the video ready.
Gordon Duguid
Gordon D #680084 27/12/20 03:36 PM
Fantastisc to see the tools you designed and the solutions you found for different tasks!
Gordon D #680085 27/12/20 03:36 PM
After an epic battle with technology I've lifted some still images from the video.
Five to start with, four to follow.
Start at the bottom and work up just like you had to do in your Working career.
By this point in the build our eldest son had graduated and was working within the oil industry as a project engineer with a crane company so the lifting plan was down to him with dad doing what he was told. We used four endless chains and two wire pullers to rotate the hull. Prior to starting I added two struts at each fixing point to take the hull weight.
Gordon Duguid
Gordon D #680086 27/12/20 03:44 PM
Yet again start at the bottom and work up, sorry. Six photos not four like I said earlier.
BM Germany, thank you, if your Scottish and don't want to spend money needlessly you have to get creative. xmasbigsmile
This was on the 11th December 2016, it took the four of us 3 hours to turn the hull. At the end of that year time spent on the build was 1350 hours.
Gordon Duguid
