1 members (HKNYMOG),
229
86
Topics49,860
Posts837,485
Posts: 1,236 Likes: 40
Boat build
Another experiment in photo posting, this photo was taken yesterday, if this works I will add earlier pictures of the build and bore you all.
Fantastic, it worked, now I can add earlier pictures if there's any appetite for them out in TM land. I might even do it there's not.π
Gordon Duguid 2014 Duratec engine plus 4, Montreal blue.
Posts: 28,899 Likes: 352
Posts: 28,899 Likes: 352 |
...when the only skill you have is hitting things with a hammer.πππ Which is usually infinitely more useful!
Posts: 2,519 Likes: 320
miles of smiles Talk Morgan Expert
Posts: 2,519 Likes: 320 |
...when the only skill you have is hitting things with a hammer.πππ Which is usually infinitely more useful!  When I get stuck , a little voice in my head always says β use the force, Ewan , use the forceβ I then spend the next few hours repairing what I broke
Posts: 1,236 Likes: 40 |
Whilst looking for the hull turning footage I came across these. This is the scarf jointing process for the plywood I mentioned in earlier posts. The two sheets are placed in the jig one on top of the other, stepped by the length of the joint, machined, then the top sheet is flipped and the two or three and a half in my case glued together using cascamite. Long lengths of wood for the hull were also created using this method. Here's the joints machined and ready for gluing. ![[Linked Image]](https://www.tm-img.com/images/2020/12/27/DSC02824.jpg) This is the scarf jig I made to create the beveling on the sheet ends. ![[Linked Image]](https://www.tm-img.com/images/2020/12/27/DSC02830.jpg) The majority of the ply was removed with a power planer. ![[Linked Image]](https://www.tm-img.com/images/2020/12/27/DSC02831.jpg) Then finished off with sandpaper. ![[Linked Image]](https://www.tm-img.com/images/2020/12/27/DSC02832.jpg)
Posts: 37,416 Likes: 977
Posts: 37,416 Likes: 977 |
Thanks again for the update Gordon fantastic watching your time lapse progress, love the pot belly stove in the wee corner.
Your skills really are exceptional.
Posts: 5,465 Likes: 171
Posts: 5,465 Likes: 171 |
This is great stuff. Following with extreme envy of your skills and patience.
BTW - it's a long time since I last used Cascamite.
Posts: 53 |
Great project, attached are some pictures of my steam launch build, strip cedar planked. https://www.tm-img.com/album/zuScRegards
That looks fantastic, do you have more photos and details of the build? That's a project that would be well worth its own thread, I'm sure others would enjoy it as well. I've spent this morning viewing the hull turning footage, there's around 40 minutes worth but I really should edit it and create something more watchable. There's a wee bit of bad language in places and a few builders bums on show  The photos are not very good but I'll post some for viewing until I get the video ready.
Posts: 2,116 Likes: 68
Posts: 2,116 Likes: 68 |
Fantastisc to see the tools you designed and the solutions you found for different tasks!
After an epic battle with technology I've lifted some still images from the video. Five to start with, four to follow. Start at the bottom and work up just like you had to do in your Working career. By this point in the build our eldest son had graduated and was working within the oil industry as a project engineer with a crane company so the lifting plan was down to him with dad doing what he was told. We used four endless chains and two wire pullers to rotate the hull. Prior to starting I added two struts at each fixing point to take the hull weight. ![[Linked Image]](https://www.tm-img.com/images/2020/12/27/00012_Moment.jpg) ![[Linked Image]](https://www.tm-img.com/images/2020/12/27/00005_Moment.jpg) ![[Linked Image]](https://www.tm-img.com/images/2020/12/27/00003_Moment.jpg) ![[Linked Image]](https://www.tm-img.com/images/2020/12/27/00002_Moment2.jpg) ![[Linked Image]](https://www.tm-img.com/images/2020/12/27/00001_Moment2.jpg)
