10 members (Gordon D, Simon, Montegue, GrumpyPa, TalkMorgan, Craig Jezz, TBM, scortroadster, chanteclair, SteveT), 453 guests, and 131 robots.
Sagging Hood
Topics49,859
Posts837,479
#746305 28/06/22 11:30 PM
Luca Offline OP
2021 M3W Torn Boot
Torn boot.
11 Comments
Luca #746307 29/06/22 03:17 AM
That doesn't look good....
Luca #746363 29/06/22 06:00 PM
Originally Posted by Luca
Torn boot.
I saw this on a 2020 car. The steering rack gators were made from quite hard plastic rather than the usual rubbery stuff so were reluctant to flex. I believe the gaiters were subsequently changed under warranty. Another own goal by MMC I'm afraid.
Andy
Luca #746576 01/07/22 05:39 PM
The bean counters probably saved 10p per side fitting the inferior gaiters.
Luca #747330 08/07/22 07:27 PM
If you need a new steering gaiter quickly they are the same as a Mk1 or Mk2 Ford Escort.
Luca #755321 11/09/22 07:27 PM
Luca Offline OP
But is that white bit even in the right place? Looks like a seal came off the rack and tore the boot. If it's only the boot at least it isn't as bad as it looks at first glance.
@planetnut Thanks. Should be fixed under warranty along with some other stuff. I've been after the dealer for a month. So far they can't be bothered to set it up. Shouldn't be this hard, but we'll see what happens.
Luca #755378 12/09/22 10:26 AM
The white plastic bit looks like the spacer that restricts the rack travel and is in the right place.
On the other hand, the gaiter is piss poor...
Luca #755399 12/09/22 02:37 PM
Some of us four wheeler owners have been suffering split / leaking steering rack gaiters on late production cars, especially Roadsters
These folk https://www.carbuilder.com/uk do a universal stepped rack gaiter that are made of a more flexible rubber
Luca #755563 13/09/22 10:22 PM
Luca Offline OP
Thanks, Calum. If it's only boot, that's one less thing, at least. Boot isn't as big a deal. I could probably split open and clamp a universal boot to cover the mess until I can get it sorted. At least I'll be able to move it without hurting anything.
Luca #756124 20/09/22 08:17 PM
Post 2018 cars have this issue - the gaiters go hard due to the heat and then tear.
White spacer is correct as Callum states.
