10 members (Simon, GrumpyPa, TalkMorgan, Gordon D, Craig Jezz, TBM, scortroadster, chanteclair, SteveT, DPEvans),
402
132
Topics49,859
Posts837,479
2021 M3W Torn Boot
Torn boot.
Posts: 7,342 Likes: 49
Posts: 7,342 Likes: 49 |
That doesn't look good....
Posts: 1,737 Likes: 55
Posts: 1,737 Likes: 55 |
I saw this on a 2020 car. The steering rack gators were made from quite hard plastic rather than the usual rubbery stuff so were reluctant to flex. I believe the gaiters were subsequently changed under warranty. Another own goal by MMC I'm afraid.
Andy
Posts: 1,796 Likes: 5
Posts: 1,796 Likes: 5 |
The bean counters probably saved 10p per side fitting the inferior gaiters.
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
If you need a new steering gaiter quickly they are the same as a Mk1 or Mk2 Ford Escort.
Posts: 40 |
But is that white bit even in the right place? Looks like a seal came off the rack and tore the boot. If it's only the boot at least it isn't as bad as it looks at first glance.
@planetnut Thanks. Should be fixed under warranty along with some other stuff. I've been after the dealer for a month. So far they can't be bothered to set it up. Shouldn't be this hard, but we'll see what happens.
Posts: 2,822 Likes: 155
Posts: 2,822 Likes: 155 |
The white plastic bit looks like the spacer that restricts the rack travel and is in the right place. On the other hand, the gaiter is piss poor...
Posts: 8,675 Likes: 490
Posts: 8,675 Likes: 490 |
Some of us four wheeler owners have been suffering split / leaking steering rack gaiters on late production cars, especially Roadsters These folk https://www.carbuilder.com/uk do a universal stepped rack gaiter that are made of a more flexible rubber
Posts: 40 |
Thanks, Calum. If it's only boot, that's one less thing, at least. Boot isn't as big a deal. I could probably split open and clamp a universal boot to cover the mess until I can get it sorted. At least I'll be able to move it without hurting anything.
Posts: 360 Likes: 36
Posts: 360 Likes: 36 |
Post 2018 cars have this issue - the gaiters go hard due to the heat and then tear. White spacer is correct as Callum states.
