0 members (),
206
35
Topics49,841
Posts837,323
Posts: 417 |
Long story short after my second battery only last 2 days it's come to my attention it's the rectifier/regulator.
anyone know or have any suggestions for it's replacement. my car is stranded at a carpark right now from last night so i don't have it in front of me to check the specs so i can call around to get a replacement.
any details or suggestions would be helpful as i'd like to get back up and running ASAP
blake sfmorgan.tumblr.com
Posts: 3,560 Likes: 12
Posts: 3,560 Likes: 12 |
I can't help I'm afraid Blake, but you have my condolences. My first thought on reading your post was "What a bu66er!'. I hope you manage to get it sorted soon. Keep us in the loop, the same could happen sometime.
If you need another rectifier, and your dealer isn't able to get one quickly, I am at the factory on Tuesday, collecting my new Three Wheeler, and I would be happy to collect one and post it on to you, so that you could get going quickly. No doubt, though, it will be under warranty and your local dealer will have to supply it. Nevertheless, bear my suggestion in mind, it really is very little trouble.
Posts: 5,013 Likes: 32
Posts: 5,013 Likes: 32 |
Is it a standard S&S fitted unit?
+8 4.8
Posts: 3,838 Likes: 9
le Asbo du Bling Talk Morgan Addict
Posts: 3,838 Likes: 9 |
Blake are you sure is the rectifier and not the alternator if the battery is not holding getting charged?
Slowly going green
Posts: 417 |
Car is getting towed to a s&s dealer/specialist as we speak. Decided to let the pros deal with this. Will keep you all posted.
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Good to hear progress is being maded. I recall another thread on here about the recitfier...
Richard 1976 4/4 4 Seater
Posts: 398 Likes: 1
Posts: 398 Likes: 1 |
I have had a similar issue recently. Battery went flat, cause traced to faulty rectifier. This a known issue, especially with the original two point mount system. S&$ people in NZ commented that standard unit was "delicate" and that a Harley unit would be more robust. This was put onto my M3W and adapted to suit the new three point mount.Cost same as stock unit better delivery on HD unit. Mind this is NZ at the end of the world ! I believe that another car in NZ has also had this issue and had the same repair
Posts: 417 |
exactly what the s&s guy said to me today. car is getting the HD one fitted tomorrow as well as an oil filter leak they spotted while doing a once over on the car. pics to follow S&$ people in NZ commented that standard unit was "delicate" and that a Harley unit would be more robust.
Posts: 417 |
Posts: 7,342 Likes: 49
Posts: 7,342 Likes: 49 |
Disappointing Blake, you’re not having much luck with this vehicle.
