7 members (MJF, B3MOG, Piloto, Rog G, John Winn, RedThree, Graham, G4FUJ), 351 guests, and 40 robots.
Adam12 69
+8Rich 67
John V6 60
9,215 Registered Users
SORN
New
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Pedal mod
Pedal mod
by RibbleAdventures, July 31
4/4 80 Anniversary Rex_Tulips
by Rex_tulips, July 31
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,368
Posts813,413
Members9,215
Rbt Aero8, Salmon, stevends
#148846 11/08/13 12:07 PM
Hi, I have a non starting 1980 Ford Kent engined 4/4.
I seem to have traced the issue to the fuel pump not working and wanted some advice on where's best to order another? Do I buy the whole pump or just a rebuild kit? Does anyone know a good supplier for one?
Thanks
Buy the hole pump (cheap) - never seen a rebuild kit - assuming you still have the engine driven version. Make sure you replace the spacer/gasket too. Stops heat transfer to the pump (cheap).
Burton Power would be my choice of supplier. You need to match the pump to your block type (711M - most probable or 681).
Both under 30 pounds.
Simples. No link - just a satisfied customer.
Give your local parts shop a ring. While the Ford Kent is ancient, the pump you need is common to an awful lot of cars and it's not beyond hope they'd have one and get you mobile faster.
Depending where you are in Herts, I bet Uncle Melvyn has one on his shelf, although you may get it cheaper elsewhere.
Snailmog,
I blocked the mount on my Kent block and mounted an electric pump back near the fuel tank. Starts instantly after sitting for days, unlike the engine driven pump. Just a thought.
Allen
'69 4/4
Allen
'69 4/4 Four Seater
E
E
Hi Allen,
What make of electric pump did you use?
1989 911 Porsche Carrera
Land Rover Series
Defender 90 SW
Originally Posted By Edgar 1969 4/4
Hi Allen,
Facet, personally.
1972 4/4 2 Seater
Facet as well.
Allen
'69 4/4
Allen
'69 4/4 Four Seater
That would be my route, if the pump failed on RTA. Together with a pressure regulator in the line.
Cheers,
'09 Gen2 MINI Cooper ragtop
E
E
Thanks, I have a new mechanical pump to install for the rebuild but might go electric as I have one on another old vehicle.
Land Rover Series
Defender 90 SW
