1 members (RedThree), 423 guests, and 37 robots.
+8Rich 69
Adam12 69
John V6 52
9,215 Registered Users
Folding Reclining Seat Knob
Goodwood Speedmog 2d august
by Nick55 - 01/08/25 09:09 PM
Walnut Dashboard
by +8Rich - 01/08/25 06:24 PM
SORN
New
Morgan plus Four 2025
by Jérôme, August 2
Pedal mod
Pedal mod
by RibbleAdventures, July 31
4/4 80 Anniversary Rex_Tulips
by Rex_tulips, July 31
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
Topics48,375
Posts813,542
Members9,215
Page 2 of 4 1 2 3 4
PhilRoyle #156207 18/09/13 06:32 PM
Originally Posted By PhilRoyle
Europa spares do a stick on one(or one srew hole if preferred - Smiths replica- no need to drill - just replaced the battery after 2 years. most think it is factory fitted!!- about £30 inc. vat.
Fits nicely to the right of the steering wheel on the dash.
Tried finding this but failed if anyone has a link.
I would like a clock on the dash, but would be more likely to try lobotomy on swmbo to cure nagging then cutting a hole in the dash for a dial.
2016 Carmine Red 991.2 C4S
PhilRoyle #156214 18/09/13 06:48 PM
Jays Offline OP
Ah....the Chronos one I think Phil. I had one in my 4/4 ( I think I might have started the trend!) and fitted one to the Roadster as a temporary measure until I plucked up courage to cut a hole! I have promised it to Graham...should look nice on Mellow Yellows dash wink
If anyone wants a Chronos clock I suggest they get one now. Chronos seem to have stopped making them although there are a few still out there on ebay or Amazon.
PS. The beauty of the Chronos is that its got a slim depth and the slip in holder can be secured with double sided tape if you don't want to drill a small hole for the mounting screw.
Jays #156241 19/09/13 02:58 AM
Looks good Jays...
Or there's this, as I had on RTA's dash:
http://www.amazon.co.uk/OXFORD-ANALOGUE-...otorcycle+clock
Available in black, silver or titanium. Mine kept really good time.
Cheers,
'09 Gen2 MINI Cooper ragtop
Looks great Jays. Very 'period.'
As previously mentioned on the watch thread, I have a similar one although mine has both an elapsed time recorder and a stop watch. Astonishingly heavy for a aircraft clock, and if you have 27volts on the Morgan, a heating element too.
Anyway - I've never fitted it to a car, but it is complicated shape being circular, with two part circles added on. I'd strong suggest you make a blank from something like a cereal packet so you can get the hole correct with no fears. Then you can draw through the hole, cut the dash ever so slightly undersize and gently file the hole until the clock fits.
The bezal is not large, so the margin for error is small, hence my suggestion of making a cereal packet hole first.
Jays #156282 19/09/13 07:22 AM
MIG clock........and the red button is for firing the missiles.........yes? laugh2
Polished result looks excellent and fitted will look even better.
Jays Offline OP
In one of the photos, the clock is resting on a drawing of the hole I need to cut.
You are right Martyn....no real margin for error...the bezel is about 3mm. Measure many times, cut slightly small and gently file as you say! I'm going to do a trial fitting in a spare piece of MDF....my main worry is chipping of the surface.
Jays #156290 19/09/13 07:44 AM
Jay - that is VERY nice and will be an excellent point of interest on the dash. Please forgive me if you know this (and you probably do, given that you bought it from Ukraine; I write this only because it hasn't been mentioned so far), but the sub-dial is a stop-watch. TM won't accept Cyrillic characters so SEKUNDOMER = "stop-watch". The button on the right is labelled PUSK = "start", so I assume the red button on the left is "stop".
St Eve #156297 19/09/13 08:46 AM
Jays Offline OP
Quite correct Steve. The Red button is for winding the clock and adjusting the time.
The Silver button stop, starts and resets the stop watch with a push and turning the knob stops and starts the clock.
A bit more complex on the multi dial clocks which have a flight duration upper dial controlled by the Red Button.
Page 2 of 4 1 2 3 4
