SORN
New
Topics48,371
Posts813,485
Members9,215
Posts: 89 |
My 2002 S1 suffers from an intermittent rustling sound from around the steering column shroud or facia above it.It particularly appears in cold weather, on any road that is less than perfectly surfaced.I have tried grease between the shroud and the facia to no avail. Has anyone else had a similar problem?
Mr Fezza Talk Morgan Expert
Posts: 2,825 |
Mine is a 2002 S1 as well, but I've had no such issue. Could just be something loose / rubbing? Best bet if to get the dealer to whip the facia off at next service - probably just a simple loose wire / piece of tape etc.
-------------- Maxxed out!
Posts: 141 |
could just be a family of mice trying to cling on to each other around those bends.
rgds Nick....just waiting for the sunshine...
Posts: 859 Likes: 1
Posts: 859 Likes: 1 |
You sure you havn't misplaced your 7 iron. I do hope its cured before my ride to the Noggin this evening.
Honda S2000 Lexus UX 250h Toyota Auris Hybrid
Posts: 89 |
Definitely not my 7 iron, I used it this morning at the Orchard with my normal aplomb. I am sure you will enjoy the run to the noggin with your head buried under the Aero’s facia for 20 miles!
Posts: 859 Likes: 1
I should have realised, as they say " There is no such thing as a free lunch"
Posts: 222 |
Leaf stuck somewhere in the ventilation system? Woodworm? Check they used Cuprinol on the frame during the build...
