1 members (scortroadster), 299 guests, and 97 robots.
+8Rich 77
Topics49,870
Posts837,667
Rudolf
Page 32 of 94 1 2 30 31 32 33 34 93 94
PaulJ #179228 31/01/14 09:39 AM
I think they may indeed with a few stable mates, which will be nice.
Q8morgan #179299 31/01/14 06:15 PM
Can't say where I heard this but apparently the centa drive unit has been tested on a more powerful engine.
Q8morgan #179300 31/01/14 06:17 PM
This engine was attached to a three wheeler by the way
Q8morgan #179306 31/01/14 07:07 PM
Mums' the word! Sorry just making mischief, but, yes it makes sense that if MMC are going to go with another cush drive unit, they want to make sure it will work with more power than they are ever likely to use, just in case some nutty customer has their engine tuned to stupid levels. Doesn't sound like anyone here would do that does it?
PaulJ #179313 31/01/14 07:35 PM
I can see a very nicely engineered set of exhaust headers going into a very sweet turbo and the power goes from around 100 up to around 150 in just one weekend's worth of work. AND $3500, I forgot that...
Dan
Q8morgan #180004 04/02/14 07:30 PM
Q
Q
900kms now...can someone take a pic of where the grease nipple for the compensator is?i would like to check on it
Q8morgan #180016 04/02/14 08:00 PM
First post in this thread shows the hole in the underside for reaching the nipple; Hole in compensator bell housing
and the second page of this post shows the nipple on the compensator with the engine out on the bench Compensator Photos .
Best of luck and have fun!
RedThree #180024 04/02/14 08:50 PM
Q
Q
Thanks, but i don't remember seeing a hole when i changed the oil..i will double check in the morning,i remember seeing a rubber cover on the top sides of the transmission..
Q8morgan #180035 04/02/14 09:40 PM
The hole (if it is there!) will be very obvious in the first bellhousing bolted to the back of the engine. If it isn't there then I suppose you probably have the earlier compensator which I think has a steel shell but no nipple.
If the hole is there but the nipple isn't conveniently lined up then you'll find it easier to turn the engine over by rocking it in gear with the spark plugs out.
Q8morgan #180080 05/02/14 06:53 AM
Q
Q
Oh ok great help thanks,october build 2013.has it?
