6 members (Paul F, DCH, Moggo, stefan s, Alan Patterson, Ian Wegg), 337 guests, and 40 robots.
Adam12 69
+8Rich 67
John V6 59
9,215 Registered Users
SORN
New
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
4/4 80 Anniversary Rex_Tulips
by Rex_tulips, July 31
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,367
Posts813,395
Members9,215
Rbt Aero8, Salmon, stevends
#250452 02/02/15 03:34 PM
I have just taken the sump of my 95 +8,because it was dripping a bit of oil (not suprising after grounding a few times)
I see that it was assembled with a sealant and no gasket
part of the leaking problem may have been that sealant was in the threads and on at least one stopped it seating properly..
Can I assemble it with just a gasket or should I use a sealant ?
If a sealant which should I be using ?
sent with oily hands
Chris
This is the sixty four million dollar question to which there is no absolute right answer. The shelves are full of gaskets in tubes and the choice seems endless. In the old days I used to go with Blue Hylomar and a paper gasket. That's what I would have used the last time I sumped a V8 engine. Nowadays sump gaskets seem more sophisticated, being either an O ring in a groove or a metal/rubber composite. Even so, on the Ford V6 it's recommended that you use a sealer at least where the front cover attaches to the block.
So all I can say is do a bit of research - go for one which stays flexible, is oil and temperature tolerant and bear in mind that one day you might want to take it off again!
Sealant as well belt and braces.
Emyr (Em)
Drive on the Wild Side
Blue Hylomar and a gasket, make sure spotlessly clean and grease free before sticking up, don't over do the sealant you want and even coating. Get a metal straight edge and match sure the sump face that go to the block up are flat and not distorted.
Adrian
Is the sump tin, if so you might do well to counter peen the holes a bit. Sorry I don't know much about the plus 8---
Ray Offline
Mild steel pressing on + 8. Would use cork gasket and blue hylomer.
Best gasket compound I've found is Wellseal
Knocks Hylomar and Hermetite into a cocked hat.
I managed to buy a tin of it for a very reasonable price. Shan't ever need to buy any more in this lifetime...
E
E
Our Suzuki Jimny Jeep, 2007 had a dripping sump last year due to salt corroding the base of the sump.
Suzuki say use a sealant. There is no gasket for sale.
I used blue hylomar and it leaked and I spent say 2 hours removing the old mastic type sealant. It was clean!!!!!!!!!!
So again removed the sump and used the Suzuki stuff at £50 a tube and that was Febuary 2013 and it is still oil tight.
To go off topic.
In 2002 my three year old Golf GTI had the same sump corrosion. It used a gasket and there were no leaking problems when replaced not using any sealant. The whole inside the engine was black and the black stuff was say 5mm deep all round including in the sump.
Wind forward 2013. Using either semi synthetic Castrol Magnatec 10W/40 for the first three changes and Magnatec 5W/30 synthetic for the next three changes.
The whole inside the engine at 53,000 miles and the sump was clean as a whistle. The latest oils have great cleaning properties and the engine only had a sight oil coloured coat on it.
I would use a specilised non setting thick sealant like the Suzuki sealant.
I will try and find a spec for you.
Ray Offline
Chris Just a thought. check you have not hit the drain plug. Ripped mine out once on the drive gate holder. Had it brazed back.
+1 for Wellseal and gasket. Apply with a roller for an even film (I use a thick sheet of glass as a working surface), clean off with white spirit. Good on cork or paper gaskets. Great stuff but stinks a bit!
