0 members (), 297 guests, and 100 robots.
+8Rich 78
Topics49,872
Posts837,704
Rudolf
Page 1 of 4 1 2 3 4
#259510 13/03/15 10:44 PM
Rog Offline OP
Here’s a little rainy day garage job for anybody that might be interested and has a saw, a file and a drill.
I always fancied a pair of sun visor but was a bit dubious that some of the aftermarket ones might clash with my mirror and not fully fold down. Also my mirror was bonded slightly off centre so decided to knock these up using perspex.
The Perspex was easily sourced cut to size, edges polished and ready to go. Thought I would try ivory in the first instance to match the car. The interesting bit was the hinges. Couldn’t find anything suitable so ended up butchering an off cut of stainless piano hinge.
Original piano hinge
Hinge sourced here http://www.ebay.co.uk/itm/Piano-Hinge-St...=item3cf071ab37
Hinge disassembled
The new hinges chopped out. The rolls have been squeezed a little to produce a nice firm fit over the pins to ward off any droop and then finally given a bit of a polish to get a mirror finish. Optional spacers added to give a little extra clearance to miss the mirror.
Hinges attached. The Perspex is 330mm x 80mm x 5mm with 20mm rads and sourced here http://www.midlandplastics.co.uk/product/ivory_133/
Might have a bash at a tinted set next, haven’t decided if I really like the ivory yet smile
Roger
Rog #259515 13/03/15 11:32 PM
Neat job! Thanks for posting.
Rob
Bavaria 46, 20% of Hunter Impala. 100% of another Hunter Impala, black 4/4 Competition
Rog #259521 14/03/15 07:11 AM
Lovely, a really neat job! How did you drill the windscreen frame? did you tap a thread in it?
Rog #259526 14/03/15 07:43 AM
Very neat job Roger. I might have a think about making some up for Nero!
Rog #259533 14/03/15 08:10 AM
Super job. Was the screen frame already drilled for the screens? I've thought of doing something similar myself but was concerned that I'd crack the screen if I drilled into the frame.
Steve L.
1996 Plus 8
N22 MOG
Steve +8 #259534 14/03/15 08:16 AM
Great job, however:
Damaging the screen is a real risk if drilling the frame. Also it's not uncommon for the glass to move in the frame as the chassis twists. So clearance when on the flat but interference when cornering or off road.
Martin (Deano)
Rog #259535 14/03/15 08:16 AM
Very nice job
And they look great
Rog #259545 14/03/15 08:51 AM
Drive on the Wild Side
Super job, well worth the effort.
Adrian
Rog #259548 14/03/15 09:12 AM
The modern screen frames have the mounting points already fitted. I'd hate to take the risk of drilling into a frame!
Hamwich #259550 14/03/15 09:19 AM
Hi Tim
The later frames have threaded lugs already there. Very neat job isn't it!
BR Colin
Page 1 of 4 1 2 3 4
