3 members (JMcL, MartO, gomog),
346
92
Topics49,872
Posts837,704
Posts: 1,705 Likes: 35
Posts: 1,705 Likes: 35 |
Here’s a little rainy day garage job for anybody that might be interested and has a saw, a file and a drill. I always fancied a pair of sun visor but was a bit dubious that some of the aftermarket ones might clash with my mirror and not fully fold down. Also my mirror was bonded slightly off centre so decided to knock these up using perspex. The Perspex was easily sourced cut to size, edges polished and ready to go. Thought I would try ivory in the first instance to match the car. The interesting bit was the hinges. Couldn’t find anything suitable so ended up butchering an off cut of stainless piano hinge. Original piano hinge Hinge sourced here http://www.ebay.co.uk/itm/Piano-Hinge-St...=item3cf071ab37Hinge disassembled The new hinges chopped out. The rolls have been squeezed a little to produce a nice firm fit over the pins to ward off any droop and then finally given a bit of a polish to get a mirror finish. Optional spacers added to give a little extra clearance to miss the mirror. Hinges attached. The Perspex is 330mm x 80mm x 5mm with 20mm rads and sourced here http://www.midlandplastics.co.uk/product/ivory_133/ Might have a bash at a tinted set next, haven’t decided if I really like the ivory yet
Roger 2011 Plus 4
Posts: 697 |
Neat job! Thanks for posting.
Rob
Bavaria 46, 20% of Hunter Impala. 100% of another Hunter Impala, black 4/4 Competition
Posts: 12,263 Likes: 320
Posts: 12,263 Likes: 320 |
Lovely, a really neat job! How did you drill the windscreen frame? did you tap a thread in it?
Posts: 14,009 |
Very neat job Roger. I might have a think about making some up for Nero!
Posts: 1,569 Likes: 12
Posts: 1,569 Likes: 12 |
Super job. Was the screen frame already drilled for the screens? I've thought of doing something similar myself but was concerned that I'd crack the screen if I drilled into the frame.
Steve L.
1996 Plus 8 N22 MOG
Posts: 5,659 Likes: 5
Posts: 5,659 Likes: 5 |
Super job. Was the screen frame already drilled for the screens? I've thought of doing something similar myself but was concerned that I'd crack the screen if I drilled into the frame. Great job, however: Damaging the screen is a real risk if drilling the frame. Also it's not uncommon for the glass to move in the frame as the chassis twists. So clearance when on the flat but interference when cornering or off road.
Martin (Deano)
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
Very nice job
And they look great
Posts: 4,896 |
Super job, well worth the effort.
Adrian
Posts: 14,009 |
The modern screen frames have the mounting points already fitted. I'd hate to take the risk of drilling into a frame!
Posts: 3,383 Likes: 14
Posts: 3,383 Likes: 14 |
Lovely, a really neat job! How did you drill the windscreen frame? did you tap a thread in it? Hi Tim The later frames have threaded lugs already there. Very neat job isn't it!
