2 members (MATTMOG, Mogdavid), 338 guests, and 80 robots.
Topics49,849
Posts837,415
DazMog, The Impaler, tlchzj79
#282494 20/06/15 02:09 PM
Has anyone polished their factory painted bonnet cowl?
I am worried that Morgan may use a different quality of aluminum or hand pick zero defect parts to polish. I did noticed that Morgan Park Hamberg offers the service as an upgrade and this got me thinking it may be possible.
The thing I am curious about as well is if a clear coat is required post polish. Can anyone with a factory polished cowl comment on this one?
Any thoughts?
2013 M3W
2025 Plus Four
HJP Offline
I polished mine , it is stainless steel so no coating required .
I stripped the paint with paint stripper , the finish wasn't too bad a few swirl marks and scratches but it polished up well .
Hugh
I've got the polished cowl and as HJP says its stainless
Rgds
That's a surprise I assumed it was aluminium
Me too
Stewart S #282535 20/06/15 06:07 PM
Try lifting it, it's not aluminium!
planenut #282553 20/06/15 07:58 PM
OK I believe you but there must be a logical reason why its not ali
Ray Offline
Try a fridge magnet on it.
Ray #282557 20/06/15 08:16 PM
It is most definitely stainless steel.
I found this out when fitting my diy cooling fan and cutting 40mm holes in the cowl. I too thought it was going to be aluminium but after quickly blunting a hole saw soon discovered it to be stainless.
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
Stewart S #282560 20/06/15 08:27 PM
It is a structural/strength issue together with the metal that goes across the car forward of the scuttle where the wipers are mounted is also steel. My +8 handbook / publicity brochure comes with a picture of the car body before painting and you can see quite clearly the different metals in construction.
