2 members (MATTMOG, Mogdavid),
338
80
Topics49,849
Posts837,415
Posts: 57 |
Has anyone polished their factory painted bonnet cowl?
I am worried that Morgan may use a different quality of aluminum or hand pick zero defect parts to polish. I did noticed that Morgan Park Hamberg offers the service as an upgrade and this got me thinking it may be possible.
The thing I am curious about as well is if a clear coat is required post polish. Can anyone with a factory polished cowl comment on this one?
Any thoughts?
2013 M3W 2025 Plus Four
Posts: 1,213 |
I polished mine , it is stainless steel so no coating required . I stripped the paint with paint stripper , the finish wasn't too bad a few swirl marks and scratches but it polished up well .
Hugh
Posts: 1,671 |
I've got the polished cowl and as HJP says its stainless
Rgds
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
That's a surprise I assumed it was aluminium
Posts: 27,809 Likes: 749
Posts: 27,809 Likes: 749 |
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
Try lifting it, it's not aluminium!
OK I believe you but there must be a logical reason why its not ali
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
Try a fridge magnet on it.
Posts: 1,625 Likes: 25
Posts: 1,625 Likes: 25 |
It is most definitely stainless steel.
I found this out when fitting my diy cooling fan and cutting 40mm holes in the cowl. I too thought it was going to be aluminium but after quickly blunting a hole saw soon discovered it to be stainless.
Posts: 37,408 Likes: 977
Posts: 37,408 Likes: 977 |
OK I believe you but there must be a logical reason why its not ali It is a structural/strength issue together with the metal that goes across the car forward of the scuttle where the wipers are mounted is also steel. My +8 handbook / publicity brochure comes with a picture of the car body before painting and you can see quite clearly the different metals in construction.
