8 members (Morganmike, Alistair, Clipper, linklaw, JohnHarris, DaveW, Robbie, Ian Wegg),
306
37
Topics49,837
Posts837,288
Posts: 5,013 Likes: 32
Posts: 5,013 Likes: 32 |
I'm not sure what amperage is put out by chargers, but I do know that the wiring from the 12v socket is slender and also passes through part of the loom. It's always been my preference to make a direct connection from charger to battery to avoid overheating any wiring. I'm sure some will think it's unnecessary, but it's how I've always done it.
+8 4.8
Posts: 7,553 Likes: 88
Posts: 7,553 Likes: 88 |
All of my vehicles have a fused Optimate connector attached to each battery. The Optimate unit is mounted on my garage wall and is fitted with a long lead. I tend to just top up the batteries if there has been no use for a couple of weeks
Bud 4/4 "Stanley"
Posts: 71 |
I had two float charge battery chargers from Halfords and I left two batteries connected for some months. When I came back to them, one was fine and is still usable a couple of years down the line.
The other, newer one on the newer charger was cooked dry and scrap.
I have now binned the Halfords chargers and use one from Claus Olson.
However I will not trust any charger to be left unattended.
Jon the Chief
1978 4/4 2str
Do you sit in the garage and watch it?
+8 4.8
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
I prefer the direct to battery method. My ctek is set up with the battery connections they supplied. I initially tried using the 12v socket in the glovebox but found that the connection was not 100% reliable as the plug/socket were a bit "loose". To me it makes sense to go direct to battery as nothing else will be in the circuit, after all it is the battery that is the focus point.
Posts: 27,802 Likes: 749
Posts: 27,802 Likes: 749 |
I have connections to the battery but through a fused link. The charger hangs on the wall so is well ventilated
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
With the kit comes several leads. On mine I made a permanent connection to the battery with the lead that terminates with a female connector. The trailing lead fitted down the side of the passenger seat. Worth taking the time to do this in my view - pumping 12 volts though the socket in the car has never appealed.
I've done something similar and since I have a four seater I have the lead tied-up behind the battery. All neat and easy and I prefer this to clips and the 12V socket.
Richard 1976 4/4 4 Seater
Posts: 11,522 Likes: 312
Posts: 11,522 Likes: 312 |
How do we ask Morgan to add a connector to the cars ? Anyone want to forward to the architecture and development dept  Perhaps wrap it around a packet of decent biscuits and lob it in the main window If they were to do a deal with CTEK and provide one of the connectors in a convenient location (no doubt as a chargeable option along with the charger itself) then everyone would benefit from this on new cars in the future. It would allow you to have a decent charger and easy to connect location when you returned home and were planning to leave it for a bit ?
Good idea so I doubt it will make through MMC
Posts: 28,890 Likes: 350
Posts: 28,890 Likes: 350 |
I thought adding one's own was part of the ownership experience/fun???
