1 members (TBM), 290 guests, and 37 robots.
John V6 69
+8Rich 66
DaveW 66
9,208 Registered Users
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Topics48,345
Posts813,037
Captain Morgan, IRWIN
I'm not sure what amperage is put out by chargers, but I do know that the wiring from the 12v socket is slender and also passes through part of the loom. It's always been my preference to make a direct connection from charger to battery to avoid overheating any wiring. I'm sure some will think it's unnecessary, but it's how I've always done it.
+8 4.8
All of my vehicles have a fused Optimate connector attached to each battery.
The Optimate unit is mounted on my garage wall and is fitted with a long lead.
I tend to just top up the batteries if there has been no use for a couple of weeks
Bud
4/4 "Stanley"
O
O
I had two float charge battery chargers from Halfords and I left two batteries connected for some months. When I came back to them, one was fine and is still usable a couple of years down the line.
The other, newer one on the newer charger was cooked dry and scrap.
I have now binned the Halfords chargers and use one from Claus Olson.
However I will not trust any charger to be left unattended.
Jon the Chief
1978 4/4 2str
Do you sit in the garage and watch it?
smile
+8 4.8
I prefer the direct to battery method.
My ctek is set up with the battery connections they supplied.
I initially tried using the 12v socket in the glovebox but found that the connection was not 100% reliable as the plug/socket were a bit "loose".
To me it makes sense to go direct to battery as nothing else will be in the circuit, after all it is the battery that is the focus point.
I have connections to the battery but through a fused link.
The charger hangs on the wall so is well ventilated
2025 MG ZS EV aka Trigger
Originally Posted By Neilda
With the kit comes several leads. On mine I made a permanent connection to the battery with the lead that terminates with a female connector. The trailing lead fitted down the side of the passenger seat. Worth taking the time to do this in my view - pumping 12 volts though the socket in the car has never appealed.
I've done something similar and since I have a four seater I have the lead tied-up behind the battery. All neat and easy and I prefer this to clips and the 12V socket.
Smile, it confuses them
How do we ask Morgan to add a connector to the cars ? Anyone want to forward to the architecture and development dept hide Perhaps wrap it around a packet of decent biscuits and lob it in the main window smile
If they were to do a deal with CTEK and provide one of the connectors in a convenient location (no doubt as a chargeable option along with the charger itself) then everyone would benefit from this on new cars in the future. It would allow you to have a decent charger and easy to connect location when you returned home and were planning to leave it for a bit ? oops
Good idea so I doubt it will make through MMC
I thought adding one's own was part of the ownership experience/fun??? grin2
'09 Gen2 MINI Cooper ragtop
