3 members (TBM, Cat302, MOGDave), 269 guests, and 41 robots.
+8Rich 86
by stumog - 26/08/26 10:24 AM
Topics49,844
Posts837,360
Page 7 of 8 1 2 3 4 5 6 7 8
drk Offline OP
Hi Draggin. Thank you for your help. I'll check all the valve and lighting system.
Morgan 4/4, Caterham Seven, Ginetta G27, TVR Chimaera
If someone can host a file for me , I can supply the relevant pages of the S&S X Wedge Service Manual that describe the assembly procedure for the rockers , with clearance details.
I normally use photobucket to host stuff , but pdf's are not images so it doesnt want to play.
Nippy, if you e-mail them to me I can put them up on my Dropbox for all to download.
You may already have my e-mail, but if not, it's in my profile so just get it there.
Let me know and I'll get them up tonight.
Dan
drk Offline OP
Thank you very much Nippy. It would be great smile
Emailed to Dan, hope it does the job for you.
drk Offline OP
Thank you very much Nippymog smile
If you have a copy of the manual now drk, have a check on page 3-42 and look at the information on "Compression Release Cams". I may be wrong but I cannot help thinking that your "problem" with valve clearances is just the compression release cams doing their stuff. They will hold the exhaust valves slightly off their seats until the RPM is over 500. Someone on TM mentioned this caused problems when trying to carry out a compression check recently. I am assuming it is the exhausts that are suspect, not the inlets? The pushrods and rockers have an initial set up procedure (page 3-4) but are hydraulically self adjusting in use. Your starting problem may be something else.
I was just able to log in and download the file to my Dropbox.
Here is the link for the S&S manual pages so graciously provided by Nippy...
Click Here For S&S Manual Pages
Ya'll have a great weekend, y'hear!
Dan
i think you did the link wrong?
kirkusblog.com
1952 Ford 8N
I just clicked it and it opened up for me. It does however look different to me as in no download button.
But if you hit Open button and then after it opens you can save it to your drive.
I'll check into this and see if I can change the link.
It seems every time I do a link, the darn options are different for me and I always have to do it a couple times to get the right "share" link.
Thanks.
Dan
