8 members (Alan Patterson, John V6, Moggo, Barkingdog, RichardV6, Craig Jezz, JohnHarris, nick w),
248
Topics49,844
Posts837,364
Posts: 133 |
Hi Draggin. Thank you for your help. I'll check all the valve and lighting system.
Morgan 4/4, Caterham Seven, Ginetta G27, TVR Chimaera
Posts: 1,562 |
If someone can host a file for me , I can supply the relevant pages of the S&S X Wedge Service Manual that describe the assembly procedure for the rockers , with clearance details.
I normally use photobucket to host stuff , but pdf's are not images so it doesnt want to play.
Posts: 1,075 |
I normally use photobucket to host stuff , but pdf's are not images so it doesnt want to play. Nippy, if you e-mail them to me I can put them up on my Dropbox for all to download. You may already have my e-mail, but if not, it's in my profile so just get it there. Let me know and I'll get them up tonight.
Dan
Posts: 133 |
Thank you very much Nippy. It would be great
Posts: 1,562 |
Emailed to Dan, hope it does the job for you.
Posts: 133 |
Thank you very much Nippymog
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
If you have a copy of the manual now drk, have a check on page 3-42 and look at the information on "Compression Release Cams". I may be wrong but I cannot help thinking that your "problem" with valve clearances is just the compression release cams doing their stuff. They will hold the exhaust valves slightly off their seats until the RPM is over 500. Someone on TM mentioned this caused problems when trying to carry out a compression check recently. I am assuming it is the exhausts that are suspect, not the inlets? The pushrods and rockers have an initial set up procedure (page 3-4) but are hydraulically self adjusting in use. Your starting problem may be something else.
Posts: 1,075 |
Emailed to Dan, hope it does the job for you. I was just able to log in and download the file to my Dropbox. Here is the link for the S&S manual pages so graciously provided by Nippy... Click Here For S&S Manual Pages Ya'll have a great weekend, y'hear!
Dan
Posts: 2,539 |
i think you did the link wrong?
Posts: 1,075 |
I just clicked it and it opened up for me. It does however look different to me as in no download button.
But if you hit Open button and then after it opens you can save it to your drive.
I'll check into this and see if I can change the link.
It seems every time I do a link, the darn options are different for me and I always have to do it a couple times to get the right "share" link.
Thanks.
Dan
