0 members (),
195
94
Topics49,849
Posts837,425
Posts: 786 Likes: 18
Posts: 786 Likes: 18 |
Without disassembling the gear lever I bought two shifter rotation rings. After dismantling I realize it takes a plastic guide and spring ball rings. I assure you that you risk not happened before 40.000km, 49400 for me.    I will give the Mazda references when I received the other parts.
Posts: 1,815 Likes: 32
Posts: 1,815 Likes: 32 |
Sorry I don't understand - did the gearlever fail?
Posts: 133 |
Hi. I have a 2012 3W but i also have a Mazda MX5. Is pretty common to change the gear stick bush because the stick begin to play a bit. From what i see in your pictures it seems that the gear stick on your Morgan was working with some kind of grease. This is unusual because all MX5 i saw in my life have the stick bush lubricated by oil ( same kind of differential oil ) Maybe this is the reason of your failure. You can try to change your lever with some short shifter kit available on line. These kind of kits have all the parts you need.
Morgan 4/4, Caterham Seven, Ginetta G27, TVR Chimaera
reference documents upper bushing: R503-17-451 upper spring: M505-17-482 lower half: R503-17-492 lower spring: 859917-482 lever guide: M501-17-515 seal paper: 0303-17-474 plastic ball: 0391-17-462A
Posts: 133 |
Very nice job. I guess your gear stick it's now perfect
Posts: 1,370 Likes: 11
Posts: 1,370 Likes: 11 |
As one lady friend opined, "It feels just like being inside a vibrator!"
I, for the first time in my life, had no words...
Posts: 342 |
I, for the first time in my life, had no words... I can understand your silence
Cheers, Georges
