1 members (Saxonian), 292 guests, and 81 robots.
+8Rich 81
Topics49,849
Posts837,424
GLLOQ Offline OP
Without disassembling the gear lever I bought two shifter rotation rings.
After dismantling I realize it takes a plastic guide and spring ball rings.
I assure you that you risk not happened before 40.000km, 49400 for me.
I will give the Mazda references when I received the other parts.
Sorry I don't understand - did the gearlever fail?
drk Offline
Hi. I have a 2012 3W but i also have a Mazda MX5. Is pretty common to change the gear stick bush because the stick begin to play a bit. From what i see in your pictures it seems that the gear stick on your Morgan was working with some kind of grease. This is unusual because all MX5 i saw in my life have the stick bush lubricated by oil ( same kind of differential oil ) Maybe this is the reason of your failure. You can try to change your lever with some short shifter kit available on line. These kind of kits have all the parts you need.
Morgan 4/4, Caterham Seven, Ginetta G27, TVR Chimaera
GLLOQ Offline OP
replacement of parts
the gear selector box is filled with oil with MoS2
the selector box is mounted with paste silicone gasket
I am pleased to found a precise gearshift.
Parts corresponding references for advanced gear lever (half / 2013).
GLLOQ Offline OP
reference documents
upper bushing: R503-17-451
upper spring: M505-17-482
lower half: R503-17-492
lower spring: 859917-482
lever guide: M501-17-515
seal paper: 0303-17-474
plastic ball: 0391-17-462A
drk Offline
Very nice job. I guess your gear stick it's now perfect smile
As one lady friend opined, "It feels just like being inside a vibrator!"
I, for the first time in my life, had no words...
I can understand your silence rofl
Cheers,
Georges
