1 members (Mogdavid), 240 guests, and 42 robots.
+8Rich 86
by stumog - 26/08/26 10:24 AM
Topics49,844
Posts837,360
Christoph
Page 3 of 15 1 2 3 4 5 14 15
I thought there were 3 baffles?
kirkusblog.com
1952 Ford 8N
You're simply baffled.
The Original Ken
11,000 miles.
2014 BMW R9T
2005 Saabaru
2005 Saabaru
Ken, truer words were never spoken!
kirkusblog.com
1952 Ford 8N
Sport exhaust with no baffles , sorted
Speed Offline OP
I took out 2 nothing from downpipe just 2 in silencer
Superdry
76 Fizzy
JVS Offline
Love the more free reving and deeper exhaust sound after completely opening up the stock system
JV Sclafani
Boca Raton, FL
'13 M3W Metallic Orange Pearl
128CI Steered by Empire - Riding on Ohlins
There are 3, 1 in front of the silencer and 2 aft which are perforated. The one in front is solid.
I guess if there are just 2 i would drill them both...
The trick I doing it so "She Who must be..." does not know i did it!
She is very anti me messing with the car.
It does only have 350 miles on it!
kirkusblog.com
1952 Ford 8N
The rear baffle already has holes in it. I took it out with a hole saw first, beacuse it was easy to reach. Much nicer exhaust sound and a marked improvement on pinking.
The front one demands two extensions on the drill (= one more) and then it all starts to wobble. Approach from the front. It has no holes in it at all, the fumes go "around" it, so to speak.
As a precaution against too much noise I have drilled four 9 mm holes in the front baffle and I am still evaluating. More, throatier exhaust rumble and the manifolds no longer glow red. Almost no pinking.
Not sure I need to use the hole saw and there is room for at least four more 9 mm holes.
Oh, a tip for you: It takes forever to get the bit to bite into the stainless, but using an impact drill made it a doddle. It took seconds to drill a hole, in stead of several minutes.
M3W, now!!!
The rear and center baffles have holes in them. I removed all three but in retrospect, I should have just removed the front solid disk and then evaluated the difference. The engine definitely pulls stronger de-baffled.
