0 members (),
258
Topics49,844
Posts837,360
Posts: 2,539 |
I thought there were 3 baffles?
Posts: 1,490 |
I thought there were 3 baffles? You're simply baffled.
The Original Ken 11,000 miles.
2014 BMW R9T 2005 Saabaru 2005 Saabaru
Posts: 2,539 |
Ken, truer words were never spoken!
Posts: 1,562 |
Sport exhaust with no baffles , sorted
Posts: 400 |
I took out 2 nothing from downpipe just 2 in silencer
Superdry 76 Fizzy
Posts: 462 |
Love the more free reving and deeper exhaust sound after completely opening up the stock system
JV Sclafani Boca Raton, FL '13 M3W Metallic Orange Pearl 128CI Steered by Empire - Riding on Ohlins
Posts: 1,796 Likes: 5
Posts: 1,796 Likes: 5 |
There are 3, 1 in front of the silencer and 2 aft which are perforated. The one in front is solid.
Posts: 2,539 |
I guess if there are just 2 i would drill them both... The trick I doing it so "She Who must be..." does not know i did it! She is very anti me messing with the car. It does only have 350 miles on it!
Posts: 400 |
The rear baffle already has holes in it. I took it out with a hole saw first, beacuse it was easy to reach. Much nicer exhaust sound and a marked improvement on pinking.
The front one demands two extensions on the drill (= one more) and then it all starts to wobble. Approach from the front. It has no holes in it at all, the fumes go "around" it, so to speak. As a precaution against too much noise I have drilled four 9 mm holes in the front baffle and I am still evaluating. More, throatier exhaust rumble and the manifolds no longer glow red. Almost no pinking. Not sure I need to use the hole saw and there is room for at least four more 9 mm holes.
Oh, a tip for you: It takes forever to get the bit to bite into the stainless, but using an impact drill made it a doddle. It took seconds to drill a hole, in stead of several minutes.
M3W, now!!!
Posts: 368 Likes: 1
Posts: 368 Likes: 1 |
The rear and center baffles have holes in them. I removed all three but in retrospect, I should have just removed the front solid disk and then evaluated the difference. The engine definitely pulls stronger de-baffled.
