2 members (JohnHarris, TalkMorgan), 345 guests, and 96 robots.
Topics49,848
Posts837,406
DazMog, The Impaler, tlchzj79
Page 4 of 5 1 2 3 4 5
Player99 #424743 25/01/17 04:15 AM
I
I
Was dreaming about the mudguard. I would be tempted to fit a stationary mudguard fixed to the frame/body structure. That way you don't have to worry about keeping the stationary parts out of the way of the moving parts (second law of machine design).
Inge
Player99 #424751 25/01/17 07:40 AM
It's still not enclosing the rear wheel down as far as the swingarm, which is a shame - it looks like what it is - an afterthought but better than nothing I'm thinking
Player99 #424779 25/01/17 09:20 AM
Grockle - thanks for photo's. Now seen your blog and realised you employed the existing rivnut for right hand bracket, and drilled/tapped for the other three. I did consider employing existing, but it seemed a tad too far back. Also the rivnut by design has a shoulder that sits proud of the swing arm surface, providing for me another reason not to use plain tapped holes, as the bracket wouldn't sit level.
If you do have an issue with threads though (bearing in mind mudguard needs to be removable) it would be a simple task to drill out the threaded holes to M5 rivnut clearance, typically 7mm, and replace with same.
Sportster #424781 25/01/17 09:36 AM
Originally Posted By Sportster
Thanks guys.
Grockle, Did you fit that yourself? Did you get it to line up with the tire properly?
Sportster,
Yes I did fit it and it does line up with the tyre. I am quite pleased the the end result.
My car is a couple of years old (early 2015). I did post some photos here
Agreed about the rivnuts Richard
Robert
Grockle #424813 25/01/17 12:02 PM
Thank you. Very nice work.
Draggin #424820 25/01/17 12:51 PM
Originally Posted By Draggin
The mudguard was a factor in my car being late. They were still prototyping it on my car. Not sure if other production ones are different.
Mines identical to yours
'16 M3W
'44 Willys Jeep
'16 Westfield 11
Grockle #424880 25/01/17 05:02 PM
Originally Posted By Grockle
Sportster,
Well it's all bolted up and looking good. The mudguard sits very slightly to the left of tyre centre line after bending brackets. However it's noticeably closer to the right side of boot tray wheel hump, although hopefully adequate clearance for the protruding locknut. Roads too mucky to go for test drive frown
Rough measurements with the bodywork suggest the wheel maybe be offset by about 3/4 inch to the right as fitted by factory. It could of course be the bodywork that's offset to the left as that governs where the tray sits wink Anyone else noticed this?
Player99 #424883 25/01/17 05:22 PM
My rear wheel was not straight from new, measured wheel rim to swing arm,out by 3/8inch at front end, noticed when fitting Ohlins... still not fitted on rear yet ! no time at mo.......
Player99 #424908 25/01/17 06:19 PM
Thanks Kevin. Guess I shouldn't be too worried, sidecar oufits have the rear wheel seriously offset wink
Player99 #424926 25/01/17 07:16 PM
As long as they go straight when you let go of steering wheel all ok i recon,
