7 members (Whizjet, Rovert, thierry242, rossocorsa, brownbaker, Marches Mark, RibbleAdventures),
342
SORN
New
Topics48,368
Posts813,410
Members9,215
Posts: 76 Likes: 3
Posts: 76 Likes: 3 |
I am preparing to change the gearbox oil in my 2011 3 litre S2 Roadster and wonder if anybody has done this task themselves. The reason for asking is that when I opened up the inspection hatch in the drivers footwell there was no gearbox filling point. Looking down the passenger footwell there were two inpection hatches so I drilled out the rivets and opened the most promising looking one. There appears to be a filling point about 50mm infront of the inspection hatch. It is going to be a real pain to firstly unscrew the filler plug (which appears to be a big oversize allen key job) then fill the gearbox with oil down a funnel and tube. Anybody done this job themselves and can you confirm that the filler is indeed the one in the passenger footwell. I am told I have a Ford gearbox in the S2. Any helpful tips from those that might have done this task would be helpful. If the task defeats me due to a lack of powered ramps I need to explain the task to my friendly local garage
AndrewD 2023 Lagoon Blue Plus Four 2019 Jaguar F Type 2024 Ford Puma ST Line X
Posts: 35,796 Likes: 474
Posts: 35,796 Likes: 474 |
Have you checked DaveW's How to in the Classic Morgan section ?
http://www.talkmorgan.com/ubbthreads.php/topics/30581/Dave's_Classic_Morgan_How_To..#Post30581
Posts: 76 Likes: 3
Yes I have been in contact with DaveW. He does not have experience of the S2 gearbox.
Posts: 288 |
Buy a cheap oil pump and do it from underneath, I did it last year and was easy. I do have a lifter though but can be done on car ramps.
Jim.
Posts: 898 |
Jim. Jim I have failed so far to find anything at less than £100 to get gearbox oil into a car when on my lift. Have bought a few things that leaked. Have you found something to pump gearbox oil that does not leak at a reasonable price yet..
Posts: 76 Likes: 3
Jim Interesting you have done a S2 gearbox oil change. Can you confirm the filler is indeed on the passenger side and did the filler and inspection hatch line up! I think getting the oil in with tube and funnel might be ok but trying to undo the filler plug might be a sod.
Posts: 9,285 Likes: 69
Posts: 9,285 Likes: 69 |
Perhaps a bit drastic but have you considered cutting a better access hole? Shouldn't be a major problem unless there is a danger of damage to parts behind the tunnel. Screwing/rivetting a cover for the hole is straight forward. Beware of heat/sound insulating material behind the tunnel though.
Posts: 288 |
I bought a cheap plastic pump from machine mart £20 It is a hand pump. Bit tedious but it works.
Posts: 288 |
Jim Interesting you have done a S2 gearbox oil change. Can you confirm the filler is indeed on the passenger side and did the filler and inspection hatch line up! I think getting the oil in with tube and funnel might be ok but trying to undo the filler plug might be a sod. Yes the filler is on the passenger side just above the drain plug. You can reach it with a plastic pipe to fill it from underneath if you can raise you car up of the floor. I used a plastic hand pump from machine mart £20 it has a loop with it that can be hung in the filler whole. Fill it until it overflows, it was around 2 litres I think. I used millers gl-5 ep 75w 80 mineral, this was recommended buy Phil at Brands Hatch Morgan. Regards Jim.
Posts: 76 Likes: 3
Jim thanks for that. I have ordered up some Morris Lodexol FS75W90 and some pre mixed Morris diff oil.
